Ignition Control Module
  • Thread starter Thread starter Gomez469
  • Start date Start date Feb 19, 2004
G
Gomez469
NY
Feb 19, 2004
  • Feb 19, 2004
Hey guys got a question. I am having problems with my stang. I'll be driving it and out of no where it cuts off. Still have power but the engine shuts off. As if fuel is no longer being delivered to the engine. I turn the car off and try and turn it on. I hear the fuel pump turn on but all I hear is the starter turning but it will not turn over. I can wait about an hour maybe 2 and then she'll turn over and I can driver her again, normally just long enough to get my a$$ home. So after talking to a few people they think I need to replace the Ignition control module. So I figured ok no prob. I go to Pep boys pick up the piece and install. Here comes the next problem. The ICM is on the distributor and I can't unscrew the second screw holding the ICM to the distributor. Can I Loosen the bolt on the block that holds down the Distributor and turn the distributor to the left so I can unscrew that last bolt and then move it back into place after reinstalling the new ICM is it that easy or is it more complicated? Thanks for the advice.
Ruben
93 teal terror
971
62
69
Durham N.C.
Feb 19, 2004
  • Feb 19, 2004
You can do that but you need to reset your timing when your done
G
Gomez469
NY
Feb 19, 2004
  • Feb 19, 2004
as you can see I'm new at this reseting the Timing is that difficult? And can you go through the steps thanks
Ruben
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 19, 2004
  • Feb 19, 2004
Paint the mark on the harmonic balancer with paint -choose 10* or 14* or something else if You have NO2 or other power adder.
Remove the SPOUT connector (do a search if you want a picture of the SPOUT connector) It is the 2 pin rectangular plug on the distributor wiring harness.
Connect timing light up to battery & #1 spark plug.
Start engine, loosen distributor hold down with a 1/2" universal socket. Shine the timing light on the marks and turn the distributor until the mark lines up with the edge of the timing pointer. Tighten down the distributor hold down bolt, Replace the SPOUT connector and you are done.
87gtconv
ragtopman
2,595
Southern Calif
Feb 19, 2004
  • Feb 19, 2004
Beat me to it and your explaination is a little better than mine!! I use chalk not paint till I know where I want car timed and I shut car off when I loosen the distributor and take spout out and put it in just to be safe.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
  • Mindseye007
  • Aug 16, 2026
Mindseye007
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Today at 11:30 AM
Scwhitten
