Ignition Control Module?
  • Thread starter Thread starter MikeUrban
  • Start date Start date Oct 20, 2010
1 of 2 Next Last
MikeUrban
187
Chantilly, VA
Oct 20, 2010
  • Oct 20, 2010
Hey everyone,
I've been having this random problem for the past two weeks or so. I'll be sitting in traffic and all of a sudden my car turns off as if I just turned the key, it doesn't sputter or anything and usually it will start right up instantly but sometimes I will have to wait up to a minute until it will start again. I've also had it happen where I'll be going to stop for a red light so I pop it into neutral and it just shuts off and I put it in third and clutch start it. I looked up the symptoms on alldata pro and it points towards the Ignition Control Module, but everyone on here talks about how it happens when it gets hot and mine does it sometimes a few seconds after starting it for the first time in the day. Does anyone else have this problem, or could it be the Ignition Control Module?
Thanks in advance, and sorry for the wall o' words.
Dino Dino Bambino
1,673
90
79
Cyprus
Oct 20, 2010
  • Oct 20, 2010
It's probably either the TFI module or the PIP sensor, but it doesn't matter which one of the two is at fault 'cause you'll need to replace the whole distributor anyway. I do suggest that you convert the TFI module to remote mount on the passenger side inner fender (SN95 style) to reduce the risk of future failure, so consider buying this kit:
McCully Racing Motors- We have exactly what your over-heated TFI Module Needs!
MikeUrban
187
Chantilly, VA
Oct 20, 2010
  • Oct 20, 2010
Thank's for the quick response! I'll try that out.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 20, 2010
  • Oct 20, 2010
Does the radio, heater or blinker go crazy when it shuts off? If so the ignition switch is bad.
MikeUrban
187
Chantilly, VA
Oct 20, 2010
  • Oct 20, 2010
nope, everything just shuts off. Also, I think alldata said something about a recall for 88-93s and their ICM. Does anyone know if there was one?
Dino Dino Bambino
1,673
90
79
Cyprus
Oct 21, 2010
  • Oct 21, 2010
Yes, there was a recall on Fox 5.0's regarding the high failure rate of their distributor-mounted TFI modules due to heat soaking. That's why you need to remote mount it in a cooler place.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 21, 2010
  • Oct 21, 2010
If everything shuts off- engine, radio, wipers, A/C blower, then it is definitely the ignition switch.
There was a FREE recall on Ford ignition switches. Since this is very old information, you may not be able to get the switch replaced for free anymore. The ignition switches overheat and sometimes catch fire. That burns up the steering column and sometimes the car interior. The auto parts stores sell the switches for $13-$15.
Saleen0679 was nice enough to dig this up for us awhile back: Replace a 1979-1993 Ignition Switch Assembly
sully88gt
Orlando
Oct 22, 2010
  • Oct 22, 2010
My car doesnt start when I turn the key, but will start when I jump the relay with a screwdriver. This problem started after i drove in heavy rain. Could a bad ignition control module be the cause? Is there any way to test the ignition control module?
HISSIN50
34
129
Oct 22, 2010
  • Oct 22, 2010
Welcome to the boards!
You'll want to start your own thread.
It's the not ig module. There's likely an issue with the interlock wiring or the solenoid itself. Jrichker will be able to provide a diagram and diagnostic to get you up and running.
MikeUrban
187
Chantilly, VA
Oct 23, 2010
#10
  • Oct 23, 2010
  • #10
I did the ICM today and on the test drive I was driving normally and then very quickly, the RPMs dropped to 0 and then jumped right back up. I guess that was it dieing and re-starting itself. I did the ignition switch last year, it's possible I left something loose. I guess that's where I should go next?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 23, 2010
#11
  • Oct 23, 2010
  • #11
Look closely at the ignition switch wiring. Look for loose wires, wires showing evidence of overheating, melting of the wiring and melting of the plastic wiring connector shell. Look for wires that are not securely fixed in the plastic wiring connector shell.
MikeUrban
187
Chantilly, VA
Oct 24, 2010
#12
  • Oct 24, 2010
  • #12
Ok, I'll try that today. Thanks for the help everyone, I hope this works
MikeUrban
187
Chantilly, VA
Nov 13, 2010
#13
  • Nov 13, 2010
  • #13
Hey, sorry to keep reviving an old thread. But this problem is killing me. I checked the ignition switch, and it was good. A few days ago my friend told me to check my grounds and when I was checking I found that my positive battery wire was horribly corroded. I changed it and my connectors and it fixed the problem for about 3 days. But now it's back. I tried scanning it with a Modis, and it said it couldn't connect. And starting yesterday it has been randomly idling at 1500, but if I start to move and then stop again it goes back to about 800 or 900. Does anyone have any other ideas on what it could be? Thanks everyone.
MikeUrban
187
Chantilly, VA
Nov 14, 2010
#14
  • Nov 14, 2010
  • #14
Anybody?
M
mr_josh
87
Nov 14, 2010
#15
  • Nov 14, 2010
  • #15
Have you done the wiggle / thump test? Get the car warm, park it in neutral, pop the hood, and start wiggling harnesses / connections and tapping on things (the ECM comes to mind). I've found many an intermittent electrical problem like that.
MikeUrban
187
Chantilly, VA
Nov 14, 2010
#16
  • Nov 14, 2010
  • #16
Yes, I tried that yesterday. I wiggled every wire and plug, tapped the TFI, jostled the battery, shook the MAF to TB hose. Nothing made it misfire. About 5 min of idling after that it shut off and then when I tried to start it and it fired right up as if nothing happened. I'm honestly thinking about doing an EFI to Carb swap now, but I don't think I'll pass emissions if I do.
nick6690
147
McDonough, GA
Nov 14, 2010
#17
  • Nov 14, 2010
  • #17
My car kept shutting off randomly and wouldn't start for a little bit and it turned out to be the PIP sensor. Try that and see what happens.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 14, 2010
#18
  • Nov 14, 2010
  • #18
You definitely won't pass the visual inspection for emissions if you do an EFI to carb swap.
Try dumping the codes. The computer monitors all the circuits and can often tell you what shut off when it wasn't supposed to.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
MikeUrban
187
Chantilly, VA
Nov 14, 2010
#19
  • Nov 14, 2010
  • #19
I'll try the PIP tomorrow, and will dumping the codes work even if the Modis wouldn't connect?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 14, 2010
#20
  • Nov 14, 2010
  • #20
Dumping the codes works as long as the computer and wiring are good. If the codes won't dump using a jumper, repost and I will try to help with the Computer won't go into diagnostic mode tech note.
1 of 2 Next Last
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
4K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
