Ignition help (small fire story inside)
  • Thread starter Thread starter TC00GT
  • Start date Start date Aug 27, 2007
T
TC00GT
104
Auburn, Ma
Aug 27, 2007
  • Aug 27, 2007
So after 6 years, I finally got the car running again. I'll keep the story short...
Saturday I tried getting it to start, and the started solenoid was clicking, car would not turn over. So I thought the solenoid was bad. I tried jumping the solenoid to see if that was the problem. Well while the jumper wire was installed, my cousin turned the key to start the car, and the ignition cylinder came out. The motor kept turning over, and we couldn't get it to stop. Finally the jumper wire caught fire. (bad I know). Once the fire was out, I was able to get the cylinder back in. I had this problem with acylinder before, and have replaced it, but it still keeps popping out. Can anyone explain why it keeps popping out? Should I replace the ignition switch itself?
Oh, and it turns out the wire from the starter solenoid to the starter was the problem. I've managed to get the car to start, but the ignition cylinder is still a problem.
one last question, when the car was turning over (not with the jumper wire) the positive side of the starter solenoid would start to smoke after repeated attempts to start. It doesn't do it now because the car starts right up, but I'm guessing that shouldn't happen. What could be the cause of that?
Any thoughts?
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Aug 27, 2007
  • Aug 27, 2007
To remove the ig. cyl., you have to insert a paper clip or similar item into the small hole on the face if it and turn the key to the left. I'm not sure but you may have to do the same thing to get it locked back into place. Have u tried this?
Your smoking solenoid was overheating from the constant cranking; might be a good idea to replace it or carry a spare as u probably shortened its life considerably.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Aug 27, 2007
  • Aug 27, 2007
Replace the ignition switch. The little tangs that hold the key cylinder in place are damaged. Fairly cheap fix and a less dangerous when you are jumping your selonoid!
T
TC00GT
104
Auburn, Ma
Aug 28, 2007
  • Aug 28, 2007
Thanks for the info, I suspected that the ignition switch was the problem. Off to Mustangs unlimited again. And I do keep a spare solenoid with me, and voltage regulator...and points...
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
