Ignition Help
  • Thread starter Thread starter Lynx331
  • Start date Start date Dec 1, 2004
L
Lynx331
308
Chicago IL
Dec 1, 2004
  • Dec 1, 2004
Im looking at getting a MSD Ignition 6AL Ignition box with rev limiter for my 87 GT. I am also going to upgrade the coil. Do i have to use a MSD coil? Because they only have up to 45,000 volts, when i found a hypertech that pushes 53,000 volts and also has a lifetime warranty. Would the hypertech coil work well with the MSD 6AL Ignition Box? Also will i need to change my wires? I have a set of accels on there now and i was looking at getting a ford racing set, would that be a wise idea? Any opinions? Thanks in advance
Rick 91GT
Mustang Master
95
99
PA
Dec 1, 2004
  • Dec 1, 2004
Any manufactors coil will work, the Accels you have now will work fine, or the FRS will work as well...take your pick.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Engine Duraspark ignition box
  • limp
  • Oct 26, 2024
Fox 5.0 Mustang Tech Jul 21, 2025
manicmechanic007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
