Ignition Key Switch Tumbler trouble
Midnight2V
224
Oklahoma
So this is one of the few areas that I am pretty short on knowledge. Any help offered would be appreciated
My keyswitch tumbler has decided to start breaking down on me. I almost got stranded and it took me twenty minutes of wiggling my key and torquing on the thing to get it to turn. For the time being I am leaving my key in the tumbler and barely turning it to off to prevent it from locking. I am locking the vehicle with my spare key. I know how to remove the steering column cover, but I have never gone any further than that.
So any suggestions on either replacing or repairing it? If repair is not an option and I have to replace it....what will PATS have to say about it?
Any words of wisdom or past experiences are welcome.
how to remove ignition key lock
If the key works, the key cylinder can be removed fairly easily. A lock smith can re-key a new lock cylinder to the same key pattern as the old. It may also be possible to just install new tumblers into the old lock cylinder.
By rekeying the cylinder to the same tumbler key pattern, reprogramming PATS is avoided.
OBTW, don't use WD40 to lub a lock. Use dry Graphite. Won't make a mess and does a better job. If WD40 is used on an external lock, it could also freeze during cold weather.
Key Release Button
Removal
Disconnect the battery ground cable.
Remove the ignition switch lock cylinder.
Insert the ignition key into the ignition switch lock cylinder and turn to RUN position.
Push the ignition switch lock cylinder release tab with a punch while pulling out the ignition switch lock cylinder.
Remove the tilt wheel handle.
Remove the upper and lower steering column shrouds.
Remove the screws.
Remove the key release button.
Remove the key release button bolt.
Remove the release button handle and the spring.
Installation
NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
To install, reverse the removal procedure.
.Quote:
.Thats why I said use only a quick shot.Then insert the key and move it around to spread the wd 40, wont hurt nuthin.
