Ignition switch / starter questions.
  • Thread starter Thread starter 88 Fox GT
  • Start date Start date Nov 28, 2004
88 Fox GT
1,674
Iowa
Nov 28, 2004
  • Nov 28, 2004
What colors are the wires comming off the back of the ignition switch that go to the starter? When I bought my Mustang it had a push button starter in it from some reason (guessing the switch went bad, but am not sure). I am guessing the colors are (1) BLACK wire and (1) BLACK/GREEN wire?
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Nov 29, 2004
  • Nov 29, 2004
If your talking about a 65, the wire from the ignition switch is red/blue, and it goes from the switch to the nuetral safety switch, then to the starter solinoid, but the color stays the same all the way.
88 Fox GT
1,674
Iowa
Dec 2, 2004
  • Dec 2, 2004
Thank you, WORTH.
I followed the wires (and looked at my old Chiltons book in the schematic) and found out there were 2 connectors not even connected.
So, for some odd reason, this car didn't have them connected and the person who owned it before me put a push button starter in it.
I connected the two connectors and the starter kicked right off with the key in the ignition switch. And this whole time I thought it may have been bad.
Thanks again.
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
M
67 Mustang Ignition Switch Wiring Diagram needed
  • Michaelell
  • Sep 14, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 3, 2026
Michaelell
M
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
