Ignition switch
  • Thread starter Thread starter Mark89coupe
  • Start date Start date Jul 31, 2005
M
Mark89coupe
206
  • Jul 31, 2005
I need an ignition switch. How much are they?
How hard are they to change? Does anyone have a picture?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 31, 2005
  • Jul 31, 2005
There is a FREE recall on Ford ignition switches. They overheat and sometimes catch fire.
Copy down you VIN number and call the Ford dealer nearest you. Tell them you want to see if the ignition switch recall for Fords & Mustangs was done on your car. They will ask for the VIN number & check it against the master database. If it isn't in the datbase, then you can schedule an appointment to have the switch replaced for free. The TSB is #95S28, and don't let them tell you that they don't do that anymore...
If you can't get it done for free, the switch is less than $15. You need some tamper proof torx bits to change it, the set is less than $10. Total labor time is less than 1 hour if the wiring isn't heat damaged.
HISSIN50
34
129
Jul 31, 2005
  • Jul 31, 2005
They are under 20 bucks and not hard to swap. They do require a Tamper proof Torx bit IIRC though.
Good luck.
EDIT: JR beat me.
M
Mark89coupe
206
  • Jul 31, 2005
Where can I get the tamper proof torx bit? Who sells the correct set?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 31, 2005
  • Jul 31, 2005
The same auto parts store that has the switch will probably have the proper torx bits.
M
Mark89coupe
206
  • Jul 31, 2005
So it sounds like I dont need to go to Ford for it? Cool. They can never help me there. I usually go to Napa.
M
Mark89coupe
206
  • Jul 31, 2005
If it fails while driving is there a way to bypass the switch or rig it?
runningmole
1,127
San Diego, CA
Jul 31, 2005
  • Jul 31, 2005
Yes. On the ignition solenoid on the drivers side (under hood). There are 2 "bolts" w/ wires. Then above them in them in the middle is a small red wire w/ a black boot.
First make sure your car is in nuetral, and the key is on, so the fuel pump has power. Then take something metal (I use a key) and touch the rear "bolt" (rear as in closest to rear of car) to the little tab that you pulled the black boot off of. The engine will crank and start. It WON'T shock you. I've been starting my car like this for the past few months....too lazy to fix.
HISSIN50
34
129
Jul 31, 2005
  • Jul 31, 2005
This would work if the only aspect of the ignition switch which was lost was the starter interlock circuit. Otherwise, if the ignition is non-operation, the car will only crank (no start).
If I had issues, I would replace the switch ASAP. Even when in 'new' condition there were issues. I would not drive one (fire hazard) with an issue at hand. Plus it is so cheap.
One can ask the counter guy at the parts store for a Tamperproof torx bit and he should know what you want. Someone in here has posted the size, but I dont recall it. A search would reveal the size so only one bit is needed to be purchased.
Good luck.
runningmole
1,127
San Diego, CA
Jul 31, 2005
#10
  • Jul 31, 2005
  • #10
Good luck.
I've already replaced the switch. Then it went out again. I haven't have the time to pull the dash to see if there is something happening under there. One of the wires (white w/ pink stripe) melted a bit under the steering column.
I know what I told him may not work, but it's worth a try. If you're stranded somewhere, you usually will try anything just to make it home (assuming you can't get in touch w/ a tow service)
HISSIN50
34
129
Jul 31, 2005
#11
  • Jul 31, 2005
  • #11
I get what you mean - you do what it takes to get going. I just did not want him to think this was a cure for a bad ignition switch (most of the time, I bet the ignition side of the switch, rather than the starter interlock circuit, is what goes south).
I dont think we even know what aspect of the switch has failed.
runningmole
1,127
San Diego, CA
Aug 1, 2005
#12
  • Aug 1, 2005
  • #12
True that amigo
M
Mark89coupe
206
#13
  • Aug 1, 2005
  • #13
Ok. I got to the ignition switch and noticed that the wire harness was not all the way in place. I pushed the harness back in and it works perfect. Should I still look into replacing the switch? It was replaced about 3 yrs ago.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Interior and Upholstery HVAC Mode selector vacuum switch issue.
  • parish99
  • Jul 3, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
KAWMAN2
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Defrost switch ignition?
  • Teen'93stang5.0
  • May 16, 2026
Fox 5.0 Mustang Tech Jun 3, 2026
Teen'93stang5.0
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
