Ignition Switch
  • Thread starter Thread starter Quick Pony
  • Start date Start date Oct 3, 2008
Quick Pony
129
Pensacola, Florida
Oct 3, 2008
  • Oct 3, 2008
I have a 1991 LX 5.0 convertible. I want to replace the ignition switch. Is it difficult to replace and will I still use the existing key for the ignition.
My turn signals will NOT work unless I touch the key cylinder slightly when the car is running!!
Would this be the ignition switch?
Thanks
Larry
Saleen0679
876
24
49
Yakima, WA
Oct 3, 2008
  • Oct 3, 2008
It's most likely the ignition switch, but not the lock/key cylinder like you're thinking. The ignition switch is an electrical assembly located below the key cylinder, behind the steering column shroud. Check out the link to get an idea of what is required. It's not a difficult job.
Replace a 1979-1993 Ignition Switch Assembly
LiquidGT
368
Near STL hell
Oct 3, 2008
  • Oct 3, 2008
You can buy the tamper proof torx bit set at a parts store if you dont already have a set.
Quick Pony
129
Pensacola, Florida
Oct 3, 2008
  • Oct 3, 2008
Thanks guys
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
