ok so i made a thread about this problem I had a while back where my timing was showing up way off on the balancer so everyone said to get a new one. Well i did that and now it still off by the same amount so now im thinking its got to be something else. The car seems to run ok, but when I point the timing light at the line, the timing marks dont even show up within range. Im not an idiot the spout connector is OUT. So its not like the comptuer is still controlling it. Do you think its possible that my distributor is off by one notch and thats what is throwing it off? I thought I had it back in right but perhaps not. Would the car even run if it was off by a notch?
You NEED to make sure it's at TDC when you put the new pointer on..............doesn't matter if it's a stock replacement or not.............the marks on the balancer may not be the same as the one you are replacing.
ran into that one twice before...restab the dizzy at TDC, and you should be fine...probably just one tooth off.
