I looked online for this and surprsingly couldn't find it. I just need the ignition timing on a 1992 Mustang 5.0 HO, I don't have a VECI label on my car, so if someone could just look on theirs. Thanks.
10 degrees BTDC is stock, most guys run 14 degrees for best performance. The 14 degrees may require you to use 93 Octane fuel.
Don't forget to remove the SPOUT jumper connector when you set the timing, and plug it back in when you finish.
