  • 1994 - 1995 Specific Tech
igniton ?
  • Thread starter Thread starter SVT126
  • Start date Start date Nov 18, 2006
SVT126
20
northern NJ
Nov 18, 2006
  • Nov 18, 2006
Hey everyone !!
I have a Clifford Cut-OFF switch that I've had for years and never had a problem with. Today I went 2 start my car by inserting the cut-off key and then placing the car key in the igniton. The car did not turn over and I lost all power. I then popped my hood and checked the battery and alternator which looked fine. I waited a few minutes and then the cut off switch light came back on and I had power. I tried turning on the car again and lost all power. I did this several times until finally the car turned over. I was talking to a friend of mine who said that its probably a bad igniton switch. Obviously their seems to be an electrical short somewhere. Any input would help. Does anyone think its the igniton switch or do u think it may have something to do with the cutoff switch that I have never had a problem with. I recently installed a Vortech S-Trim blower and a superchip, would this have anything 2 do with it? Also after the Vortech install one of my pulleys is extremly loud at idle, any reason for this? Thanks in advance
HISSIN50
34
129
Nov 18, 2006
  • Nov 18, 2006
As I recall with those chip kills, the red LED flashes real fast after you insert the chip. Does yours flash fast?
I'd take a look at battery cable connections. Jumper cables are great for running in parallel with existing cables to find a bad one (I.e. run a jumper from the negative battery terminal to the engine, etc).
And just for confusion's sake, there are circuits on the starter-interlock circuit. They turn off when the car is 'cranking'. This can make articulating when power is lost, and what components lose power, all the more important.
Good luck.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
gkomo
94 kill switch wire question
  • MrPerfect2
  • Dec 11, 2025
1994 - 1995 Specific Tech Jan 10, 2026
fasterthangas
F
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
