  • SN95 4.6L Mustang Tech
IHI turbos
  • Thread starter Thread starter 40th GT
  • Start date Start date Nov 4, 2006
40th GT
916
Lawrenceville, GA
Nov 4, 2006
  • Nov 4, 2006
So my friend with an old mazda mx-6 turbo is swapping out his stock turbo for an aftermarket one. He's giving it away and I want to know if I can use it on my car. Of course I need fuel upgrades, tune, and plugs but is it a good turbo to use? It's an IHI RHB5. I hear these are used in the old t-birds and 2.3L stangs.
StangGT96
94
El Paso, TX
Nov 4, 2006
  • Nov 4, 2006
Way to small to use only one.
40th GT
916
Lawrenceville, GA
Nov 4, 2006
  • Nov 4, 2006
So is it okay to use 2?
hotmustang331
2,967
Bastrop,TX
Nov 4, 2006
  • Nov 4, 2006
Find some specs on it with google, and ill tell you. Need at least the A/R on both the hot side and the compressor side. That should give enough info. But im going to go out on a limb and say that even 2 would be too small.
If the turbo is too small, your power will just flat die in the upper RPM, but you would have instant spool up and massive amounts of nearly instant torque.
40th GT
916
Lawrenceville, GA
Nov 5, 2006
  • Nov 5, 2006
I don't know what A/R means but people on the mazda forums are saying that it is .60/.63.
So do you think that top end performance will decrease even with 2 of them?
EDIT: I may just have to decline the offer. I'm finding that these turbos can barely handle 200whp.
Jackie Chan
I didn't read this.
2,507
Orlando, FL
Nov 5, 2006
  • Nov 5, 2006
i you want a turbo go with a master power t70. its the way to go
hotmustang331
2,967
Bastrop,TX
Nov 5, 2006
  • Nov 5, 2006
I looked around and it looks like the compressor side is decent at somewhere around a .55 A/R. But the hot side is VERY small...like a .48 A/R and that absolutly kills topend power. Here is a pic of a modified one (there are a few differnt versions but I believe the hot sides are all the same...this one has a larger compressor side though) Look at how small the hotside is. PERSONALLY i wouldnt touch it...
My turbos have a .50 A/R comressor side....68 A/R exhaust side...and a 57 trim wheel on the compressor side. (Thus why its a 57MM) These turbos are actually good for somewhere a bit over 400RWHP each. I reccomend getting something atleast around that size....I got mine for $250 each on Ebay . Just hope you can fabricate lol.
EDIT: Oh yea and definatly go with a twin setup....with like my twin 57s, they will spool up faster than a single T-70 and have more power potental. Its a proven fact that you can put a single T-88 on one engine and put 2 T-76s on another of the same spec. Say the T-88 hits a full 15PSI @ 3500RPMs and has a peak power potental of 750RWHP.....then if you size the twin 76s correctly and run them, they will not only spool up a few hundered RPM faster but will have a higher peak power potental. Or you can size the t-76s to spool up at the same time the single 88 does, but they will absolutly blow it away interms of power potental.
I am NOT saying that the twins would make more RWHP over a single on a stock GT, but its like the difference between a 1.7L KB and a 2.2KB. You wont see much differnce at low/same boost on a stock motor, but when you want to go for it and crank up the power, then the difference will really show up. And all the while the boost will come on sooner, and your exhaust will actually sound good
P
Pennywise2
Banned
May 16, 2006
1,379
  • Nov 5, 2006
You hit the nail right on the head.
That would be a excellent turbo to use on a street driven car.
That turbo is quite small I agree but,efficient for a daily driver
because it will spool very quick.You could use that turbo on your
car.It is complicated peicing together any turbo kit though without
the know-how of course.
the98stang
2,408
Clovis, CA
Nov 5, 2006
  • Nov 5, 2006
Custom fabricating is a B1TCH. I put TTs on my old Mitsu 3kgt....and it was hard ass work. You'd be better off buying a SC that bolts straight on, or the TT kit from MPH. Unless you HAVE to time to do all that custom fabricating.
I would go with a small AND large turbo. One that spools hella fast for low end, one monster for the top end.
40th GT
916
Lawrenceville, GA
Nov 6, 2006
#10
  • Nov 6, 2006
  • #10
For now my goal is to have 370rwhp. Nothing too crazy, this car is a DD. This IHI turbo that I'm looking at is made for 4 cylinders (small) so it should spool hella quick. So I can use a huge turbo in conjuction with the IHI to compensate for the top end loss. Correct?
What type of turbo should I use as the second one? I'm thinking that the 57mm that hotmustang331 recommended should be good enough.
Jackie Chan
I didn't read this.
2,507
Orlando, FL
Nov 6, 2006
#11
  • Nov 6, 2006
  • #11
you guys are making this way too difficult. if you are fabbing this, you want to keep it simple. go with a nicely sized single and you will make great low end power as well as top end. this is the wrong forum to LEARN on. you really need to go over to turbomustangs.com and search. if you said you were going to use that turbo on your car you would be ridiculed
40th GT
916
Lawrenceville, GA
Nov 6, 2006
#12
  • Nov 6, 2006
  • #12
Well then, thanx for saving me from embarassment. I'll just pass up this offer.
Jackie Chan
I didn't read this.
2,507
Orlando, FL
Nov 6, 2006
#13
  • Nov 6, 2006
  • #13
seriously. everything you want to know is on that site already. there are not as many mod motor set ups, but that really shouldnt even matter. all you really need is a nice rotating assembly and some stout valve springs and a 2v can make mad power with a nice single.....upwards of 600 with fuel and tuning
hotmustang331
2,967
Bastrop,TX
Nov 6, 2006
#14
  • Nov 6, 2006
  • #14
Yea, they probably would be pefect for him IF he stays happy with his goal of 370RWHP...as those would probably get him there @ around 10PSI.
The thing would probably feel about like a kennebell though lol, and make peak power at around 4800RPM....but after that power would probably drop like a rock. I doubt he could even tell it was a turbo lol.
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
