need help i have built my first efi2.3 na after building 7 carb versions
i used a rebuilt short block with flat tops and arp bolts
head is a n/a unit that was remachined
cam is a woleverine cs666 whitch is supposed to be a factory turbo copy
pacesetter header thru 2 inch pipe into a flow master
this combo has no bottem end and mid range is no better than the old worn out unit
i have a racerwalsh cam gear set @ 0 degrees
timing set at 10 btdc with plug removed
any ideas im confused
thanks in advance
bill
thanks in advance
bill
