5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
Heres the new combo so far :
I ordered a 306 kit. and a TFS stage 1 cam. new lifters and rods so everything is new in motor. will get new timing chain kit thats adjustable also
Here are the details.
NEW 302/306 FORD KIT
NODULAR IRON CRANK, CNC PROFILED LIGHTWEIGHT FORGED I-BEAM RODS AND PROBE FORGED PISTONS!!
THIS 302/306 KIT FEATURES:
NEW HAWKS RACING 302 3.000"" STROKE NODULAR IRON CRANKSHAFT WITH STD/STD SB FORD JOURNAL SIZES
NEW 302 5.090" CNC PROFILED LIGHTWEIGHT FORGED I-BEAM RODS WITH APR WAVE-LOC BOLTS (PRESS-FIT)
NEW PROBE .030 FLAT TOP, PIN FIT PISTONS PISTON AND PINS (9.0CR/58cc)
NEW PREMIUM ROD AND MAIN BEARING SET STD
+.030 PREMIUM RING SET
I have Thumper Ported e7te heads with stock valve size and upgraded springs. I plan to go ahead and reuse these heads. I am building this for daily driver in my vert and ocassional track use. I went with forged so I can add a Nitrous kit for the track.
My currant motor is the thumper heads stock bottom end ...comp cams nx264hr cam 512 lift 212/218 @ .050 with 1.7 roller rockers its .544 lift. I have cobra intake and 65 mm TB 24# injs and pro m maf calib for 24#.
I plan to reuse all of these items above with one exception. I am using the TFS stage 1 cam advanced 2 degrees at thumpers suggestion.
"TFS 1 cam and install it at 105 ( 2* advanced), it will have more duration than the 264 cam ( 221-225 vs the 212-218 ) still has the 112 LSA for a good flat torque curve and setting the cam in at 105 will launch you off the stops!! The lift will be a little shorter 528-540 vs 544-544 and with the high velocity of the heads will scare you!! The idle will be more raspy yet still controllable and the power will amaze ya!! I always thought the cam you chose was a little small, but that is just me!! Torque is the intake center line on the cam... the TFS1 has a 107*, anywhere from 104-106 is good!! you could even advance it as much as 4* ( 103*) and still pull like hell thru the entire RPM range .5800-6K!! I have done a few AOD cars with less heads than you ( gasket matched and egr removed...by me of course) and they LOVED it, and the heavy vert will also!!"
The argument that a E7TE small intake port head needs more exhaust flow then intake is the part I was referring to as
