My 92GT has a knock that has the rhythm and sound like a rocker arm hitting a valve cover, but I cannot pinpoint where it is coming from.
The knock disappears when I run the motor without the serpentine belt. So this tells me I have a problem with one of the accessories (AC Compressor, Power Steering Pump, Water Pump, or Alternator), correct?
I've turned each of the accessories by hand and do not find anything unusual.
So I am wondering if anyone has had an occurrence of a knock when tension is put on the crank pulley. Would a bearing inside the engine only produce a knock if tension were put on the pulley?
Does a Harmonic Balancer produce a knock before it goes bad?
Thanks in advance for your help.
