  • 1994 - 1995 Specific Tech
I'm at a loss
  • Thread starter Thread starter AP1995V6
  • Start date Start date May 24, 2007
AP1995V6
547
Oxford, MS
May 24, 2007
  • May 24, 2007
I'm changing the O2 sensors on my car, and the drivers side was no problem to get to. Infact, I was able to remove it with a wrench. However, the passenger's side sensor is a different story. I've seemingly taken every approachable angle with have the car on just jacks. I have the O2 socket, but I get about 1/2" in any direction, if that, to move my drive.
Anyone have some sort of tip/trick/anything on how to remove that bass-terd?
[These are pre-cat, fyi]
AP
R
red95gtconvert
382
Ponca city, OK
May 24, 2007
  • May 24, 2007
You might try loosening it when the exhaust is good and hot just try not to burn yourslelf or worrt case senario you might have to drop your H pipe to get at it. I would use antiseize on reassembly. Good luck.
1TallMF
955
Montreal
May 24, 2007
  • May 24, 2007
Problem is they make those O2 sensor sockets with 3/8" drives, well at least mine was. I had the same problem with the passenger side. After snapping a crappy 3/8" extention like plastic, I used the highest quality 8" extention I had laying around with a 1/2" adapter at the end put onto a 1/2" drive breaker bar (a big no no I know, but it worked). Then I had a buddy hold a torch flame up to the outside of the threaded pipe insert and cranked it loose. It broke loose with a loud bang too, that sucker was on there good. Hope this helps.
HISSIN50
34
129
May 24, 2007
  • May 24, 2007
Each H is differently oriented but I use never seize on the threads, which allows me to use a crescent wrench on the O2. In case that helps..............
I do recall that on the 88, there's a lot more room than on my 94 (where the pass. O2 nearly hits the frame).
Good luck.
Bosko5.0
1,067
longwood, FL
May 25, 2007
  • May 25, 2007
use a wrench stick your hand right behind the tire in the wheel well, Thats how I did myne When I had shorty pipes. now they are located in the h pipe right after the longtubes
O2 socket always bent and started stripping the O2 sensor So I use a wrench.
94-302-vert
1,947
NE CT
May 25, 2007
  • May 25, 2007
I vote closed end of a wrench on the O2 then use another wrench on that for leverage... I have had to do this several times... The worst part is getting the wiring through the 7/8 (i think) wrench so you can do this. The reason I like this is the wrench load is in line with the O2 nut so there is less chance of it slipping off while torqing the living daylights out of it...
Oh and heat does help... You may want to put the first wrench on first then run the car or use a torch....
(raises hands in air in victory)... I haven'e been beaten by an O2 yet!!!
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 26, 2007
  • May 26, 2007
I have a foot long 3/8" ratchet that has a flex head with the O2 socket. It seemed to do the trick. I do believe I had to hit the end of the ratchet with a hammer to initially break it loose. Kind of a pseudo-impact wrench but it worked.
Scott
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
  • dan50
  • Jul 18, 2026
dan50
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
