Im getting a 9 inch!
  • Thread starter Thread starter stephen4785
  • Start date Start date Oct 10, 2004
stephen4785
321
Fort Worth Texas
Oct 10, 2004
  • Oct 10, 2004
Im puttin a fuel pump in my buddy's Firebird and hes giving me the 9 inch rear end out of his truck.He says its got 3.73's and limited slip. I guess ill find out once its out. I know Im gonna have to get it shortened and stuff re-welded.Does anyone know what the length of the axle should be to fit a 65 GT?
88 Fox GT
1,674
Iowa
Oct 10, 2004
  • Oct 10, 2004
Wow, sounds like a good deal. Yeah, it will need shortened.
Anyway, according to this site it needs to be 52.25" wide for a 1965 Mustang.
http://www.ultrastang.com/Rearinfo.asp?Page_ID=1
allcarfan
The Answer Man
2,458
North Atlanta
Oct 10, 2004
  • Oct 10, 2004
some of us men already have a 9"-er
HEHEHE.
Congrats though!
1320stang
4,329
23
89
Edmond, Oklahoma
Oct 10, 2004
  • Oct 10, 2004
You'll also have to get a 4.5" pattern drilled in the axle flanges, and make sure the center of your wheels will fit over the center hub on the axle. Might be easier to get Moser to make you new axles with the right hub and stud spacing, then all you have to do is redrill the drums for the 4.5" pattern. Or you can get new wheels, but then you won't be able to rotate your wheels and tires.
latamud
791
Tampa, FL
Oct 10, 2004
  • Oct 10, 2004
If you use your 8in tubes and have them sectioned onto the 9in housing you can use your old axles and not have to worry about modding the truck axles, unless they are 31 spline. My experience with the above quote cost me about 60% of the cost of Moser custom axles. If you're gonna try shortening the axles you mind as well order customs and have them sized specifically for the frear you will put in the car. That means you could try narrowing from the stock housing to fit different wheel sizes under the car. Have fun.
stephen4785
321
Fort Worth Texas
Oct 10, 2004
  • Oct 10, 2004
anyone have any idea of how much custom axles from Moser would cost?
2bav8
2,511
Mesa, AZ
Oct 10, 2004
  • Oct 10, 2004
I spent just under $400 for my Moser axles.
stephen4785
321
Fort Worth Texas
Oct 10, 2004
  • Oct 10, 2004
I just checked the the moser site and they run 295$.
stephen4785
321
Fort Worth Texas
Oct 10, 2004
  • Oct 10, 2004
Yeah I think Im just gonna get the Moser's.I also think Im gonna get a rear disc setup instead of messin around with the drum crap.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
