im leakin like hell
1FatPony
241
when ever i look under the car there is shiit all over the ground. its red shiit so i think it is the transmission fluid. i can also see the drips coming from the transmission. i can also see the gears in the transmision box on the bottom. is that right?? do u think the seals are broken or something?? i dont kno??
If you can see gears then I'd be suprised if there's any fluid left in the box to leak. Have you lost some kind of inspection plate? Where can you see the gears? I wouldn't recommend driving your car till you get his sorted out.
ive got some pics
vbgarage.php
vbgarage.php
vbgarage.php
...thats really weird. DOes it look like the tranny has slipped away or does it look like just a spacer,gasket, or plate is missing from it? cuz to me for some reason it looks like the tranny has slipped away. Either way I definately wouldnt drive it until you get that fixed and get some new transmission fluid back in it.
Stop! Man o Man.....
It's just missing the inspection cover. Many cars are missing the inspection cover. It's no big deal, you can drive it that way. That is your flywheel, not a gear in the tranny. If the tranny were seperating form the ingine, you would know it by now.
Bring it to a shop and have them check for leaks. They will probably need to get the thing good and clean and start from there.
lol. I think everyone was about to have a seizure there for a minute. Like Max said, it's just the inspection cover. Would probably be a good idea to get one though. I imagine all of the dust and such getting up in there will eventually take it's toll.
I did the same panic thing when I found out my cover was missing. Dad explained what it was, I've gone ten years as a daily driver without it and never had a problem. I actually had completely forgoten about it until now. :D
Check the two tranny lines for leaks, the dipstick o-ring, and most of all the tranny pan. People always overtighten the pan and bend it so it doesn't want to seal anymore. Another very likely possibility is a leaking power steering line; that stuff will blow everywhere when you are driving down the road making it hard to track down. Wipe a rag over the hoses and bend them back and forth; I bet you'll find they are cracked and need to be replaced.
Don't worry about the inspection cover and that is called flexplate on an automatic transmission.
