My plugs are white and so are the Hego's. I have a voltmeter off of the sig wire for the 02 on the right side. Ran it into the Car to see what there doing while I'm driving. When It's cold I read 0.22, once it's hot I read while cruzzing 0.17. Gas it and it drops to 0.06 Then I'll get a check engine light. According to ProM's web site 0.33 is way Lean I need to see something like a .8 for it to be right. The 02's are new with the act,ect I tried a different MAF and checked for vaccum leaks as well none where found. I also tried a new EGR valve. The fuel pressure is set to 40 with the vaccum off, Adding Fuel has no effect. The motor is stock with a new 155lph fuel pump. I'm at the Brick wall with no where to go. I know whats wrong but can't FIX it. I'm down to the EEC or maybe Injectors Being Bad. Any help you can give would be helpful thanks.
