Improperly Installed Intake = Engine Revving By Itself? Wtf
  • Thread starter Thread starter Boss 351
  • Start date Start date Jul 14, 2012
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Jul 14, 2012
  • Jul 14, 2012
Hi guys, a friend of mine with a carb'd 5.0L GT asked me for some help. He changed the intake, distributor and installed an MSD box. Car would start, revv up to 4k or whatever by itself then die (no idle)...
I checked the dizzy install, found TDC and all - it was all installed properly. But the intake manifold was missing a bolt (cylinder #4) and wasn't torqued... I'm thinking the intake is leaking air, allowing the engine to "bypass" the carb and revv up until it ran out of fuel? Does that make sense? I'm sure ignition can't cause this symptom...
Thanks
aar0s
1,015
55
69
Jul 14, 2012
  • Jul 14, 2012
my first guess would be air leaking around the intake gaskets causing it to rev.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jul 14, 2012
  • Jul 14, 2012
Definitely a significant vacuum leak going on.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Jul 14, 2012
  • Jul 14, 2012
throw the MSD box away just in case....
but yes, vacuum leak is where I'd start. Id think youd see more of a surge than just a hanging throttle though.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Jul 14, 2012
  • Jul 14, 2012
Leave the msd... One step at a time... Do a bunch of changes it might end up doing goofy stuff.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Jul 14, 2012
  • Jul 14, 2012
I would think the car would just run rough and maybe die at idle, but I dont know about just reving to 4k by itself from a vacuum leak. Definitely fix the intake and then go from there. The throttle cable is hooked up to the carb correctly and isn't stuck?
Boss 351
Jul 13, 2003
2,433
23
48
Canada
Jul 15, 2012
  • Jul 15, 2012
Yup that's why I posted, it's so weird. There's no way the ignition system can do that to an engine. I'm not entirely sure if it goes up to 4k, just sounds like it (tach is dead). Starts, goes up in revvs and dies. Throttle cable is installed ok.
srtthis
5,129
1,666
204
Maryland
Jul 15, 2012
  • Jul 15, 2012
What kind of carb?
Boss 351
Jul 13, 2003
2,433
23
48
Canada
Jul 15, 2012
  • Jul 15, 2012
srtthis said:
What kind of carb?
Stock Carb on Weiand intake with EGR spacer installed. Bolt missing on cylinder #5 water area, not properly torqued either... I didn't install the intake but suggested to get the bolt out and re-install with a torque wrench and following the proper tightening pattern...
srtthis
5,129
1,666
204
Maryland
Jul 15, 2012
#10
  • Jul 15, 2012
  • #10
Sounds to me like the air fuel screws need adjusted... When we were adjusting the new carb on the race car the car would have a run away idle till we got the air fuel screws adjusted right
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
