  • SN95 4.6L Mustang Tech
Improve handling without lowering?
  • Thread starter Thread starter ssbauer
  • Start date Start date Sep 16, 2005
ssbauer
58
Springboro, OH
Sep 16, 2005
  • Sep 16, 2005
I would like to improve the handling on my near stock 02 GT (added a catted X). Without getting into a big discussion on the why or the 4x4 look, I do not want to replace the stock springs at this point. I have some good reasons.
I just want some general handling improments for daily driving. I don't go to the track, but I have done a little (very little) autocross. Plus, I would like to reduce the rear end hop.
Doing some searches on this forum, I have narrowed initial modifications down to three possibilities.
- Subframe Connectors, stiffening the chassis. Less twist around corners and when accelerating and maybe reduce wear and tear on the car. Standard or Full length?
- Replace shocks/struts. I assume Ford didn't initally put good ones on. A quality set should improve handling and ride. Bilsteins?
- Panhard bar. Fix that rear end hop?
The question is what should come first, which combo should come first, or I am way off base to begin with? I am leaning toward starting with subframe connectors. Opinions and suggestions are welcome...
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 16, 2005
  • Sep 16, 2005
1. Full lenght subs - for less twisting and better chassis structure, you can't go wrong. It is one of the more common 'first mods'
2. Upgrading for better springs always leans tward a drop in height, you can find Mach 1/Bullitt springs which are stiffer than stock but only drop as low as .75 to 1 inch. Doubt you will find something stiffer and retain the factory height. Even though I would like to hear the reason why you like the 4X4 look.
3. Bilsteins are a much harsher ride but it will handle better, if you can deal with a harder ride, go for them.
4. Panhard bar... is a great choice but you should upgrade other rear componets first like a Solid replacment Rear Sway Bar (OEM Cobra, Steeda etc.) and look into at set of Lower Control Arms like Maximum Motorsports or Pro3i's LCA's. That'll help with the hopping and give a better feel in the turns.
BLUE03GT
281
Sunnyvale, Ca.
Sep 16, 2005
  • Sep 16, 2005
what spring/shock n strut package would make for the smoothest ride?...
40th GT
916
Lawrenceville, GA
Sep 16, 2005
  • Sep 16, 2005
Something like drag racing suspension..
twogts4us
4,188
12
79
Dunedin, FL
Sep 16, 2005
  • Sep 16, 2005
MRT makes a nice handling package, with minimal lowering.
I'd do full length subs (MM is what I've got and love em - VERY heavy and VERY long), then MM, Steeda or UPR lowers and FRPP uppers.
D
dromeda
146
  • Sep 16, 2005
Subframes are pretty much a must. Simple, cheap and reduces a ton of twist. I'd do these first IMO. If you want to see how effective they are, just jack up one corner (on the frame) of the car before you put them in, then jack the same corner up after you do it. It's scary once you see what the car does compared to with subframes.
On the other hand my cobra has a complete Griggs Racing GR40 Autocross setup, and well it handles nicely.
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Sep 16, 2005
  • Sep 16, 2005
Great advice, Tom.
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 17, 2005
  • Sep 17, 2005
Did you choose the PHB or the watts?
StangPro
441
Roseville, MI
Sep 17, 2005
  • Sep 17, 2005
Without changing springs, I wouldn't change dampers right away as they are tuned together.
Try SFC's and something like Steeda's aluminum LCA's, then sway bar bushings and either c/c plates with a good alignment or the poor man's version of just getting a set of poly upper strut mount bushings. Also, remove the quads when you do the LCA's to take some friction out of the system.
This is a good starting point.
BlueRuckus
204
Miami, FL
Sep 17, 2005
#10
  • Sep 17, 2005
  • #10
Some other options:
Strut Tower Brace
G-Trac bar
Front and rear anti-sway bars.
Better Bushings all around.
Full length sub frame connectors for sure.
One of the first mods I did to my car was the Strut Tower Brace and I felt the diff. right away.
As far as your question about which first. I would say sub-frames, STB and sway bars.
Just my $.02 Good luck.
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 17, 2005
#11
  • Sep 17, 2005
  • #11
BlueRuckus said:
Some other options:
Strut Tower Brace
G-Trac bar
Better hurry with that G-Trac bar, I heard they are discontinued
D
dromeda
146
#12
  • Sep 17, 2005
  • #12
The kit came with the PHB so I got that, though I would love to feel how a watts setup handles.
wms004
2,864
Los Angeles
Sep 17, 2005
#13
  • Sep 17, 2005
  • #13
Without changing the stock springs, its going to be hard to receive cornering benefits.. Even going to Bullitt springs which barely lower the car at all would be better than nothing.
Otherwise, Bilstein Struts and Shocks are what you want. I've tried Tokico premiums and wasn't a huge fan. The bilsteins are amazing.
Secondly, you want Rear Lower Control Arms to get rid of wheel hop and keep the back end planted while accelerating through corners. www.maximummotorsports.com
Wade
juiced_94gt
1,143
Southern California
Sep 17, 2005
#14
  • Sep 17, 2005
  • #14
I don't agree with the bilstein thing, when they are matched it's a caddilac smooth ride and a definate corner hugger, with my front coilover kit with 300# springs and HD bilsteins, my car rides smoother and more comfortably over bumps and when you launch into a corner it stay's flat, bilsteins adjust themselves to road conditions and will give you a pleasent ride over uneven pavment with the cornering you are looking for, there is a reason for them beign expensive, if you have stiff springs and adjustable shocks and set them to soft, your just going to end up with a bouncier uncontrolled ride because the car will be over sprung, trust me i chucked my tokico illuminas in the garbage after 5k and the bilsteins where the best investment i ever made, do yourself a favor and call the Maximum motorsports tech line and they will explain everything to you.
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 17, 2005
#15
  • Sep 17, 2005
  • #15
I don't agree with the bilstein thing, when they are matched it's a caddilac smooth ride and a definate corner hugger, with my front coilover kit with 300# springs and HD bilsteins, my car rides smoother and more comfortably over bumps [/QUOTE]
That's cause your springs/struts are in unicen, you should try the 500's
ssbauer
58
Springboro, OH
Sep 18, 2005
#16
  • Sep 18, 2005
  • #16
I don't necessarily like the 4x4 look, but at this point the current ride height will work out better for me. This might change in the future so I won't rule out springs totally.
So it sound like SFCs are a must, then possibly LCA and rear sway bar. I'll need to find a shop to do the SFCs. Probably not the thing to learn to weld on. LCA and sway bar I can do myself...
All, thanks for the help.
juiced_94gt
1,143
Southern California
Sep 18, 2005
#17
  • Sep 18, 2005
  • #17
even if you just upgrade to bilsteins you will feel a big improvement in handling with the stock springs.
ssbauer
58
Springboro, OH
Nov 21, 2005
#18
  • Nov 21, 2005
  • #18
The dead shall rise again!
I just had full length SFC welded on. Big improvement; feels like a different car, quieter ride, handles bumps much better. Haven't tried any hard corners yet. It is probably my imagination but it shifts better too.
Now on to LCAs...
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
