improvements
  • Thread starter Thread starter 873Stang
  • Start date Start date Jul 19, 2007
873Stang
221
riverside
Jul 19, 2007
  • Jul 19, 2007
hey on the 1/8th mile im getting mid 10's i could make it high 9's if i improve my reaction time. the only things done are in my sig motor is stock. so if i were to but the x pipe with borla mufflers, bbk long tube headers and changed the diff to 373, could you guys guess what my times may be then??? oh and thinking about bbk ssi intake or professional products spyder intake for efi. thanks
stang_hp
62
cartersville Ga.
Jul 19, 2007
  • Jul 19, 2007
Your car would be in the low 9's, until you do a h/c/i swap or the bottle. Oh by the way take the audio system out when you race it less weight faster the car.
873Stang
221
riverside
Jul 20, 2007
  • Jul 20, 2007
whats an h/c/i ???
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jul 20, 2007
  • Jul 20, 2007
High/Mid-9's with street tires (assuming you're cutting at least 2.0X 60ft times), Low-9's/High-8's with drag radials. You're going to need real power to get much quicker than that. More that basic bolt-ons will give you, i'm afraid.
And H/C/I stands for Heads, Cam, Intake.
ninety15.0
1,336
  • Jul 20, 2007
whats the equivalent of a 9.0 1/8 mile pass in 1/4 mile ET. I think you should definitely change the gearing...that will make a huge difference. I think i dropped almost .5 seconds in the quarter when i went from 2.73's to 3.73's. Also think about subframe connectors and a nice exhaust set-up.
kck6894
Advanced Member
Mar 18, 2004
Paradise
Jul 20, 2007
  • Jul 20, 2007
Your reaction time has nothing to do with your ET or your MPH.
Sicarius428
2,085
Jul 20, 2007
  • Jul 20, 2007
What is your budget? Gears will definately help and while you are down there some control arms would be help complete the rear end. Subframe connectors would be nice to tighten up the car. Exhaust for a stock motor unless your cats are clogged really doesn't net you very good hp per dollar. Full exhaust will run you at least 1k so I would put that money elseware. I would shy away from the SSI and get something proven like an Edelbrock/typhoon or cobra/gt40/explorer if you are keeping the stock heads for now. They will work just fine once you get heads but if you get a Holley or TFS you really can't take advantage of them till you get some better heads.
Kevin
stang_hp
62
cartersville Ga.
Jul 20, 2007
  • Jul 20, 2007
My car went 9 flat with basic boltons like what you posted, street tires and 3.73's. I have'nt been able to drive my car with the new setup posted in my sig, so it's driving me crazy. I need to get it tuned. Oh by the way that was with another person in the car with me.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Jul 20, 2007
  • Jul 20, 2007
I was hoping somebody would say that. The clock starts when your car moves, not when the light turns green.
873Stang
221
riverside
Jul 21, 2007
#10
  • Jul 21, 2007
  • #10
:SNSign: wow thx for all the help!!!! my bugent isnt much i haveto slowly do things, and perfomance parts are going to be awhile nowthat i have to geta rack for her now. (thinking cobra sn95 rack) off set bushingscuzmycaris lowerwed in the front. but yea i think ill start off with diffs then sub fram connects then exhaust. then internal motor work.
speaking of which, i been looking at twin turbo kits on ebay. what would you say to those??? if i do it everythings has to be forged right??? also there set to 8psi, on a street car is that ok, is daily driver, would that kill me in gas???: SNSign:
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
  • dan50
  • Jul 18, 2026
dan50
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
