improvements
873Stang
221
riverside
hey on the 1/8th mile im getting mid 10's i could make it high 9's if i improve my reaction time. the only things done are in my sig motor is stock. so if i were to but the x pipe with borla mufflers, bbk long tube headers and changed the diff to 373, could you guys guess what my times may be then??? oh and thinking about bbk ssi intake or professional products spyder intake for efi. thanks
High/Mid-9's with street tires (assuming you're cutting at least 2.0X 60ft times), Low-9's/High-8's with drag radials. You're going to need real power to get much quicker than that. More that basic bolt-ons will give you, i'm afraid.
And H/C/I stands for Heads, Cam, Intake. :)
whats the equivalent of a 9.0 1/8 mile pass in 1/4 mile ET. I think you should definitely change the gearing...that will make a huge difference. I think i dropped almost .5 seconds in the quarter when i went from 2.73's to 3.73's. Also think about subframe connectors and a nice exhaust set-up.
Your reaction time has nothing to do with your ET or your MPH. :nice:
What is your budget? Gears will definately help and while you are down there some control arms would be help complete the rear end. Subframe connectors would be nice to tighten up the car. Exhaust for a stock motor unless your cats are clogged really doesn't net you very good hp per dollar. Full exhaust will run you at least 1k so I would put that money elseware. I would shy away from the SSI and get something proven like an Edelbrock/typhoon or cobra/gt40/explorer if you are keeping the stock heads for now. They will work just fine once you get heads but if you get a Holley or TFS you really can't take advantage of them till you get some better heads.
Kevin
My car went 9 flat with basic boltons like what you posted, street tires and 3.73's. I have'nt been able to drive my car with the new setup posted in my sig, so it's driving me crazy. I need to get it tuned. Oh by the way that was with another person in the car with me.
:SNSign: wow thx for all the help!!!! my bugent isnt much i haveto slowly do things, and perfomance parts are going to be awhile nowthat i have to geta rack for her now. (thinking cobra sn95 rack) off set bushingscuzmycaris lowerwed in the front. but yea i think ill start off with diffs then sub fram connects then exhaust. then internal motor work.
speaking of which, i been looking at twin turbo kits on ebay. what would you say to those??? if i do it everythings has to be forged right??? also there set to 8psi, on a street car is that ok, is daily driver, would that kill me in gas???: SNSign:
