I didn't have time before, but just to get back to original question for a moment:
Cool67 said:
Does anyone know which brake upgrade gives you the most improved stopping power for the money: 1) upgrading the front drum brakes with disc brakes, 2) adding a power booster to the drum brakes 3) or is there another better way of improving the brakes.
A front disc brake conversion is probably the best thing to start with to improve braking, in addition to converting to a dual resevoir master cylinder (which you'll need if you switch to discs anyway). Sure you can spend dones a bunch of cash on Wilwood, SSBC, or Baer, which is great if you've got the cash.
If you don't have a bunch, you might be tempted to
try to go cheap with a
used Granada swap. Notice the words in bold type... try and used... lots of folks have done the Granada swap with good success, but after hearing about many of the conversions, I don't think they're all that cheap after you buy all the used parts and rebuild the calipers, hone the rotors (or get new ones), new hoses, etc. Instead, consider a less expensive all new component kit from R&C Motorsports for $350:
http://www.rcmotorsports.net/page13.html . I only know these guys by reputation, but they're supposed be good.
Anyway, beyond the front disc upgrade and a new dual well master cylinder, you'll probably want to add a power brake booster, an adjustable proportioning valve, good pads, sticky tires, and a good balanced suspension. I talked about some of this stuff in another thread recently. You might check it out:
http://forums.stangnet.com/showthread.php?t=513418&highlight=brakes
Hope this helps...
