I'm hemorraging oil out of the drain plug so I have ordered a Canton 7 qt pan. How difficult is the swap with the engine in the car? Any tips/advice? Also, should I go with the 1 piece gasket or the 3 piece? I MUST have a leak-free seal.
Max Power said:I just disconnected the idler arm from the frame to drop the linkage. If the crossmember hasn't welded itself in, this is a pretty easy task.
thehueypilot said:I agree and I would use a good quality one piece pan gasket using "the right stuff" gasket sealer in all the corners (front & rear main bearing saddles) and where the front cover splits.
68keyblr said:Dumb question: what is "the right stuff"? Specific brand?
302 coupe said:assuming you can unbolt the crossmember, its not bad at all. The bolts holding that crossmember in can be a real bear sometimes though.... Other than removing the crossmember, you shouldn't have to do anything else.
D.Hearne said:It's a shame you couldn't use the pins, those little jewels are priceless in installing the pan, gasket, stiffeners while the engine is rightside up.
68keyblr said:I agree, the idea is fantastic and would have worked beautifully with a stock pan. But you guys know me...gotta do it the hard way![]()
