inertia switch/fuel pump problems
capnzzz
11
Hello, recently the 91 stang has not been turning the pump on while key on..hence no start. The inertia switch input wire has power. The output wire does not have power at all. When I pull the harness out of the switch and jumper it the voltage goes to zero??? Is this a short on the fuel pump end? I would figure putting a jumper would present the 12v to the pump. Any ideas?
Fuel Pump Troubleshooting for 91-93 Mustangs
Revised 21-Oct-2011 to Add location of fuel pump relay on 91 model year cars
Clue – listen for the fuel pump to prime when you first turn the ignition switch on.
It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the upper RH corner to ground.
attachment.php
If the fuse links are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this. You can rent or get the loan of a fuel pressure test gauge from most of the major auto parts stores.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump Relay:
On 91 cars, it is located under the driver's seat.
On 92 and 93 cars it is located under the MAF. Be careful not to confuse it with the A/C WOT cutoff relay which is in the same area. See the diagram to help identify the fuel pump relay wiring colors.
Be sure to closely check the condition of the relay, wiring & socket for corrosion and damage.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect
for fuel escaping while pump is running.
Theory of operation:
Read this section through several times. If you understand the theory of operation, this will be much easier to troubleshoot. Refer to the diagram below frequently.
Diagram of the fuel pump wiring for 91-93 cars.
attachment.php
The electrical circuit for the fuel pump has two paths, a control path and a power
path.
Remember that the computer does not source any power to actuators, relays or injectors, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The control path consists of the computer, and the fuel pump relay coil. It turns the fuel pump relay on or off under computer control. The switched power (red wire) from the ECC relay goes to the relay coil and then from the relay coil to the computer (light blue\orange wire). The computer provides the ground path to
complete the circuit. This ground causes the relay coil to energize and close the contacts for the power path. Keep in mind that you can have voltage to all the right places, but the computer must provide a ground. If there is no ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like fuses, except they are pieces of wire and are made right into the wiring harness. The feed wire from the fuse link (pink/black wire) goes to the fuel pump relay contacts. When the contacts close because the relay energizes, the power flows
through the pink/black wire to the contacts and through the dark green\yellow wire to the inertia switch. The other side of the inertia switch with the brown\pink wire joins the pink/black wire that connects to the fuel pump. The fuel pump has a black wire that supplies the ground to complete the circuit.
Power path:
Power feed: Look for 12 volts at the pink/black wire (power source for fuel pump relay).
No voltage or low voltage, bad fuse link, bad wiring, or connections. Remember that on 92 or later models the fuel pump relay is located under the Mass Air meter. Watch out for the WOT A/C control relay on these cars, as it is located in the same place and can easily be mistaken for the fuel pump relay.
Relay: Turn on the key and jumper the ECC test connector as previously described. Look for 12 volts at the dark green\yellow wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed, or there is a broken wire in the relay control circuit.
Inertia switch:
The location for the inertia switch is under the plastic for the driver's side taillight.
There should be a round plastic pop out cover over it, remove it to access the switch button.
With the test connection jumpered and ignition switch in The Run position as described above, check the brown/pink wire. It should have 12 volts. No 12 volts there, either the inertia switch is open or has no power to it. Check both sides of the inertia switch: there should be power on the dark green\yellow (inertia switch input) and brown/pink wire (inertia switch output). Power on the dark green\yellow wire and not on the brown/pink wire means the inertia switch is open.
Press on the red plunger to reset it to the closed position. Sometimes the inertia switch will be intermittent or will not pass full power. Be sure that there is 12 volts on both sides of the switch with the pump running and that the voltage drop measured across the switch is less than .75 volts.
Pump wiring: Anytime the ignition switch is in the Run position and the test point is jumpered to ground, there should be at least 12 volts present on the black/pink wire. With power off, check the pump ground: you should see less than 1 ohm between the black wire and chassis ground.
Make sure that the power is off the circuit before making any resistance checks.
If the circuit is powered up, your resistance measurements will be inaccurate.
attachment.php
Control path:
Relay: The red wire for the fuel pump relay coil gets its power feed from the ECC relay.
No 12 volts here, and the ECC relay has failed or there is bad wiring or bad connections coming from it. The ECC relay is located on top of the computer, which is under the passenger’s side kick panel. It is not easy to get to, you must have small hands or pull the passenger side dash speaker out to access it.
Relay: The light blue/orange wire provides a ground path for the relay power. With the test connector jumpered according to the previous instructions, there should be less than .75 volts.
Use a test lamp with one side connected to battery power and the other side to the light blue/orange wire on the fuel pump relay. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. Remove the test jumper from the ECC test connector.
With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow.
No glow and the wiring between the computer and the fuel pump relay is bad.
Computer: If you got this far and everything else checked out good, the computer is suspect.
Remove the test jumper from the ECC test connector located under the hood. Probe computer pin 22 with a safety pin and ground it to chassis. Make sure the computer and everything else is connected. Turn the ignition switch to the Run position and observe the fuel pressure. The pump should run at full pressure.
If it doesn't, the wiring between pin 22 on the computer and the fuel pump relay is bad.
If it does run at full pressure, the computer may have failed.
Keep in mind that the computer only runs the fuel pump for about 2-3 seconds when you turn the key to the Run position. This can sometimes fool you into thinking the computer has died.
Connect one lead of the test light to power and the other lead to computer pin 22 with a safety pin.
With the ignition switch Off, jumper the computer into self test mode like you are going to dump the codes. Turn the ignition switch to the Run position. The light will flicker when the computer does the self test routine. A flickering light is a good computer. No flickering light is a bad computer. Remove the test jumper from the ECC test connector located under the hood.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
for help on 88-95 wiring Mustang FAQ - Engine Information
Fuel pump runs continuously:
The fuel pump relay contacts are stuck together or the light blue/orange wire has shorted to ground. Remove the fuel pump relay from its socket. Then disconnect the computer and use an ohmmeter to check out the resistance between the light blue/orange wire and ground. You should see more than 10 K Ohms (10,000 ohms) or an infinite open circuit. Be sure that the test connector isn’t jumpered to ground.
If the wiring checks out good, then the computer is the likely culprit.
Prior to replacing the computer, check the computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up next to the starter solenoid where the wire goes into the wiring harness.
Confused...shouldn't both wires to and from the inertia switch have power when key on? I didn't think the fuel pump received its power input from anywhere else (according to the op's faq above). And if the input at the switch is receiving power, does that not rule out everything downstream from there as well??
"Check both sides of the inertia switch: there should be power on the dark green\yellow (inertia switch input) and brown/pink wire (inertia switch output). Power on the dark green\yellow wire and not on the brown/pink wire means the inertia switch is open."
Key on, yes power to both wires on the inertia switch. No power on brown/pink and the inertia switch is either tripped or burnt. Pop the cover off it and push the red button back down. The inertia switch pops in a collision to cut power to the fuel pump so you don't have fuel spraying all over. When it does that it cuts power to the other side of the switch. So running it should have power to both sides. When tripped or bad the brown/pink side will be dead and no power to the fuel pump. Look at jrichker's diagrams again. He just lead me through this stuff and you need to understand it yourself to further diagnose problems.
update...replaced fuel pump..checked all connections. Still not priming when key on. Same issue as before power to green/yellow wire on inertia switch but no power on output brown/pink wire. Jumping the inertia switch the voltage goes from 12v to zero on the brown/pink wire. I am stuck here and have no idea what else it could be. Any other ideas?
Sound slike the intertia switch has been tripped ... try resetting it. Then check it with an ohm meter with it "tripped" and "not tripped" . You should have no continuity with it tripped and continuity between the terminals with it reset properly and working.
Follow the troubleshooter I posted and you will find the problem. You can guess and get all sorts of weird input like check the blinker fluid, or follow the troubleshooter test path and find and fix the problem quickly.
Update..checked fuel pump relay under seat..it is clicking when key on..battery power to red lead (from ignition) and constant power from pink lead..switched power from relay is turning test light on for a couple of seconds then off. When hooking up light to constant and the other lead to ground wire (blue/orange) llight lights up...then goes off indicating a good ground from ecm. So it looks like the fuel pump relay is working as it should and all the tests check out there. Still stumped??
you probably have a bad wire from the inertia switch to the fuel pump. if the hot to the inertia switch has power and the other wire does not it is either the switch itself or the wire. you jumpered the wires and bipassed the inertia switch with no power to the pink/brown at the pump? then the wire is bad. the computer is doing what it is supposed to do but without that power the pump will never run. look at the diagram, pink/brown is the only supply to the pump.
attachment.php
found out where the problem lies...I tested the red wire coming into the relay..less than 12v..jumped connection between red wire and pink wire and it started right up. So..does this mean fuseable link, ecm relay, or ignition switch?? Also would it be okay to leave the jumper in there for the interm? I pulled the plastic panel of the passenger side kick panel but cant find the relay up in there.
Thanks
Thanks
Did you end up resolving the issue.. I know 10 years ago lol! But I’m having a similar thing going on. Relay gets 12v, pump won’t prime. Thanks!
Fuel pump relay need a trigger to signal it to turn on. This comes from the ECU in terms of a switched ground, and a constant hot to the relay coil that comes from the EEC relay.
I suggest a new thread with specifics as you what year your car is so that the proper wiring diagrams can be provided to point you to what you should test.
Reactions: Shakerhood
