  • SN95 4.6L Mustang Tech
Info needed before tuning!
  • Thread starter Thread starter 01Saleen-465
  • Start date Start date Jun 24, 2006
01Saleen-465
46
Michigan
Jun 24, 2006
  • Jun 24, 2006
Today I finished putting on the following parts on my car and now need to get a tune.
Chicane RIPP CAI
Chicane 66mm S/C pulley
SVT Focus fuel pump
Accufab 75mm TB
NGK TR6 plugs
I have never had a dyno tune done before and I am not sure what to look for in a good tuner. There is only one shop in my area that does dyno-tuning, so I want to make sure that they will be checking for everything that needs checked. If they don't, my only other option is to go the mail order tune route. My ? is what needs checked and measured besides h.p., torque, and A/F? I also have a 90mm LMAF and 42lb injectors that I haven't installed because I am not sure if I will need to. Will the tuner be able to tell me if I am pegging my MAF meter and if my injectors are maxed out? I plan on using a SCT tuner with an X-cal II because I heard it is the only one that will read the Saleen "powerflash".
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Jun 25, 2006
  • Jun 25, 2006
Order a mail-in tune from MPH they will also be able to tell you all you need to know. Just tell them your mods and what you want.
Pearl02
496
Kansas City
Jun 25, 2006
  • Jun 25, 2006
The best way to go is to a dyno. What type of tuning device will they use(SCT X-Cal,Diablo Sport or some type of chip). I'n sure they'll check youe A/F ratio. Also see if they can datalog the car for you. The datalogger can be set up to check other parameters of the car(fuel curves,O2 sensors,timing,and so on). I see that your S/C'd so You should probably install your MAF and injectors. Some one else chime in here. You'll definitely want a hand held tuner so you can "play" around with things. This is the advantage you'll have over a chip. You'll also be able to data log the car yourself. Call them and see what's up. Pearl02.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
