Info on 331 w/ HCI
  • Thread starter Thread starter huntnfish09
  • Start date Start date Jun 13, 2005
H
huntnfish09
18
  • Jun 13, 2005
Looking to put in a 331 stroker kit into the stang as well as a HCI upgrade while keeping cost to a minimum.
Anyone have a similar combo with HP gains, 1/4 ETs, or set-up?
Who sells a reasonable priced stroker kit? how much $$
Any info on the Holley systemax kit.
Thanks in advance,
Adam White
Sicarius428
2,085
Jun 13, 2005
  • Jun 13, 2005
The holley kit is really nice but also consider the track heat trick flow kit. It includes the roller rockers too unlike the holley kit.
Kevin
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Jun 13, 2005
  • Jun 13, 2005
If your gonna put that much $ into a 331, dont waste your time on doing a TFS or Holley setup.
Ok, but you forgot to mention a few things.....
whats your budget?
How much HP do you want?
Where are you located?
When do you wanna build?
What heads do you have/what ones can you afford?
Do you wanna get used parts to save $?
Get a custom cam that is MADE FOR YOU!
H
huntnfish09
18
  • Jun 14, 2005
After more searching on this and other forums I think I plan to go with a explorer intake, thumper heads and some bigger injectors, and all the little stuff to make it work.(those little parts add up). Will this flow well enough to feed the extra cubes of a 331?
I read a column in Engine Master Magazine saying they got a 331 stroker kit from ?Pro Power? for $775. I couldn't find the same kit on their website though. As far as harmonic dampener and balancing go how much would the stroker cost?
I really don't have a budget as I make decent money being in Iraq for another 6 months, and nothing to spend it on. I am CHEAP! Anything I can get cheaper slightly used or junkyard parts is always a plus!
Adam
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Jun 14, 2005
  • Jun 14, 2005
Down low it will be great, at the top (5000+) it will be more choked than having better breathing parts.
I think they moved towards the modular crowd
huntnfish09 said:
I really don't have a budget as I make decent money being in Iraq for another 6 months, Adam
H
huntnfish09
18
  • Jun 14, 2005
This was Junes Engine Masters Mag. I wouldnt think that it would change that quickly. Does anyone know of another company that sells a kit at that price and quality? It was all scat equiptment I think?
9
90Notch
1,046
Westwood, MA & yes it's killing me that I'm no
Jun 14, 2005
  • Jun 14, 2005
If you are buying the assembly, heads, intake, TB, etc. expect to be spending minimum $5000. Don't skimp on the kit if you do you'll pay for it later. Cheapest I've seen a kit with bearings and rings is just under $1000. I'm guessing that $775 kit doesn't include rings & bearings.
Modular2v
3,222
23
99
oklahoma
Jun 14, 2005
  • Jun 14, 2005
i ordered my 331 kit from Performance automotive wearhouse for 890$....this included scat crank, forged i beam rods and forged probe flat top pistons, rings and bearings to of course...it is an additional 150$ to have them balance the crankshaft
Modular2v
3,222
23
99
oklahoma
Jun 14, 2005
  • Jun 14, 2005
dont forget you are going to have to have the block bored and the skirts on the cylinder walls will have to be notched, you will have to have it hot tanked and new freeze plugs...total cost there is around 500$
H
huntnfish09
18
#10
  • Jun 14, 2005
  • #10
a 331ci short block is starting to look pretty good right about now.
Do you have to get an new short block balances with your flywheel and dampener?, or can you just give them specs and its done for you?
Modular2v
3,222
23
99
oklahoma
Jun 14, 2005
#11
  • Jun 14, 2005
  • #11
just give them your specs and they can do it for you
N8Miller
2,661
Kingston, PA, USA
Jun 14, 2005
#12
  • Jun 14, 2005
  • #12
there is no way in my life that i would put an explorer intake and a set of thumper heads on a 331. (no offense to thumper!)
please research more parts.
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
V
Suspension New Power Steering Rack Options - 1990 GT
  • Vix
  • Sep 2, 2020
2K
Fox 5.0 Mustang Tech Sep 2, 2020
Vix
V
N
Engine build advice 331 NA vs 306 with possible boost
  • NO TESLA 4ME
  • May 9, 2019
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2019
Anti_Hero0932
D
Drivetrain My 08 4.0 pony has a wounded clutch?!
  • Dingey3628
  • Apr 20, 2019
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 20, 2019
Dingey3628
D
