Bear with me here guys, I'm in the middle of moving and I just got a promotion so my life is real hectic and I haven't had time to search this. My brakes are on the edge of failure. I want to go with the Cobra brake swap, 13" front, 11.75" rear.
If I go with one of the kits from PPI or speedconcepts, are there any modifications I'll need to do beyond that? Banjo bolts and brackets are included.
I know a larger master cylinder is recomended, anyone have a specific part #? Ford or Brembro?
How about the zinc plating compared to the gold plating, what are the differences/advantages?
What about cross-drilled/slotted vs blank rotors?
Any info you guys could give me would be greatly appreciated. Thank you.
Both will help keep the rotor from rusting wherever the brake pads DON'T touch. The pads will eventually eat through the zinc/gold, but the rust won't be as bad as unprotected rotors.
