  • 1994 - 1995 Specific Tech
Info on swapping a compete exploror engine!
  • Thread starter Thread starter OrangeMustangGt
  • Start date Start date Apr 13, 2004
OrangeMustangGt
1,976
Cape Cod, MA
Apr 13, 2004
  • Apr 13, 2004
Info on swapping a compete 98' explorer engine!
Can it be done? I guess its the same basic thing. Will it give me the same amount of power as if i put the p heads on my engine, etc. A local junk yard will not part the heads, but they sell completete engines. They have one with low miles for 800. Will it drop right in, as far as mounts, oil pan, emmissions,pullys etc? I could always swap stuff from mine. I know i will have to get some 94-95 p headers, that is fine. Im just wanting to get an idea on if this is possible, and worth it b4 i call the JY and tell em to hold it.
OrangeMustangGt
1,976
Cape Cod, MA
Apr 13, 2004
  • Apr 13, 2004
has anyone done this? is it a waste of time?
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Apr 13, 2004
  • Apr 13, 2004
At the longblock level they're compatible. Accessory brackets are different, ignition is different, induction is different (but fixable). Not sure if the oil pan for the Explorer motor will fit in a Mustang, might have to swap yours.
Dave
88lx5oh
36
  • Apr 13, 2004
i would just say f it and buy the motor then swap everything off of it u want i.e. heads and intakes. its well worth the 800. just look at the price of the heads alone (about a grand)
331 cobra
398
Silicon Valley CA
Apr 14, 2004
  • Apr 14, 2004
P's for $1,000, tell me where you shop and I'll avoid it like the plague.
I think you should just be able to pull the timing chain cover and pan and plug in a distributor. That should do it besides electronics. I would be very tempted to put in a new cam and a better timing chain while everything is out in the open.
Good luck.
GTPhreak
5,505
Rowlett, TEXAS
Apr 14, 2004
  • Apr 14, 2004
you can get the heads that are on that motor for 3-400, 1k is entirely to much for a set of gt40/gt40p irons
OrangeMustangGt
1,976
Cape Cod, MA
Apr 14, 2004
  • Apr 14, 2004
yeah, true; is there any way to make sure that is has the gt-40 p's? is it marked anywhere? also, what cam is best, and where can i get headers? thanks!
Maxboost50
302
Louisiana
Apr 14, 2004
  • Apr 14, 2004
I think like Hairycanary touched on about ignition, it has a different firing order than the GT's. If Im not mistaken, in order to change that, you would have to change the cam. Although, you could run the Explorer firing order. I am also about 90% sure the oil pan is completely different. Ours has two sumps to make room for the K-member.
timk
156
st.louis, mo
Apr 14, 2004
  • Apr 14, 2004
buy the engine, and sell the parts you don't need to the explorer crowd. there are lots of people into that s.u.v.
that's what i did. bought a 6k mile explorer engine from a salvage yard, complete throttle body to pan for $800. then, i sold the intake, throttle body, coil packs, wiring harness, oil pan, accessory brackets, valve covers, injectors and flywheel, and i actually MADE money.
M
madams74
664
Maryville, TN
Apr 14, 2004
#10
  • Apr 14, 2004
  • #10
What kind of junkyard sells an engine without heads? What a bunch of crap! That is unheard of. Most junkyards wont sell the accessories (power steering, alternator, smog, etc) already bolted on an engine in a sell. This crap with the heads is a joke.
OrangeMustangGt
1,976
Cape Cod, MA
Apr 16, 2004
#11
  • Apr 16, 2004
  • #11
what mustang cam would work best with this setup?
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
M
1993 2.3 Auto to 5.0 Manual
  • malikaimiller08
  • Aug 28, 2024
3K
Fox 5.0 Mustang Tech Aug 31, 2024
95steedamustang
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
J
Exhaust Manifold search
  • joekurt
  • Apr 10, 2024
1974 - 1978 Mustang II Talk & Tech Apr 12, 2024
extra_stout
