Injector activating when engine off
  • Thread starter Thread starter acmjg
  • Start date Start date Sep 24, 2005
A
acmjg
  • Sep 24, 2005
1990 5.0 runs very rich at idle mainly on right side. I noticed today with the key on engine off, #2 injector was activating intermittently (could hear it clicking away). Pulled #2 plug and cranked motor and got a gas bath. Bad computer??
I would appreciate any help!!
Anthony
stang22
1,318
Washington, D.C.
Sep 25, 2005
  • Sep 25, 2005
When you turn the key on, the injectors should pulse/charge. I am not sure about the ticking and why you are getting a gas bath from it. Did you pull any codes?
Tim
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 25, 2005
  • Sep 25, 2005
Fuel pressure OK, the injectors are not firing, OR one or more injectors stuck open
The red wire on each injector is powered up whenever the ignition switch is in the Run position. The computer provides a ground to complete the circuit and fire the injector. The injector must have a ground to squirt fuel on command. A short to ground in the injector return wiring can cause one or more injectors to be continually open or triggered
A.) A Noid light available from Autozone, is one way to test the injector wiring. If the light stays on constantly, either the wiring has a short to ground or the computer has failed
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles An injector stuck open will release a continual stream of bubbles. Cheap if you have the stuff laying around, and works good too.
The wiring for the injectors may have some bare spots in it causing the injector to computer control wire to ground out. This would cause the injector to remain on anytime the key was in the Run position. Remove the injector wiring connectors from the injector. Note that each injector has one red wire for power and a non red wire (wire some color other than red) for computer controlled ground. With the key off, use an Ohmmeter between the non red wire and ground. You should see more than 100 ohms resistance.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. You’ll need it to do the cylinder balance test
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
Second method is the cylinder balance test. Warm the car's engine up to normal operating temperature. With the Engine Off, Key OFF, use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 99 or the number of the failing cylinder such as 22 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
  • brandyn200
  • Jun 20, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
