Im needing a MAF and injector preference for my 94 Cobra turbo build. Im going to be running about 12psi. I have a stock Explorer block ( I know it wont last long but Im saving for a Dart block I just want to get all the good parts now and only buy them once). Im running a single 66mm turbo with a 50 shot out of the hole to help it to spool. My mods are 75mm throttle body, Comp Polymers upper and GT40 lower, World Products Windsor Sr. 200 heads with 64cc combustion chambers, custom ground FI cam. I need to know what size injectors I need to buy and what MAF and size I should buy. I talked to C&L and they said I should not have any bends before the MAF and that I need to shield the filter if I put it on the end of the MAF. Is this true? I also hear of a blow through MAF what is this? THIS IS MY FIRST TURBO BUILD. Im doing the turbo install with my friend that does turbo Hondas all the time. I just need advice on my MAF and injectors. Thanks
