  • SN95 4.6L Mustang Tech
injector/fuel pump
  • Thread starter Thread starter mustangjoe02
  • Start date Start date Sep 2, 2011
M
mustangjoe02
84
  • Sep 2, 2011
just wondering, if you have upgraded injectors, do you have to upgrade the fuel pump?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 2, 2011
  • Sep 2, 2011
How much HP are you making? How much HP do you plan to make?
The fuel pump should be sized to match. A needlessly large fuel pump can cause it's own set of problems. The symptom is different depending upon return or return-less fuel system.
Not a lot of information to go on. Not proud of your ride? Sure seems like it due to the lack of detail/effort in the thread.
M
mustangjoe02
84
  • Sep 3, 2011
im just wondering because im pretty sure i have 24# injectors (on the car when i bought it) but when i tune for them, its like its harder to start the car on a cold start. however runs fine after that.
Maxpowers
859
Pittsburgh, Pa
Sep 3, 2011
  • Sep 3, 2011
That's a bad tune. If the car runs fine and has power after it starts, then it obviously isn't the fuel pump.
M
mustangjoe02
84
  • Sep 3, 2011
arent light blue injectors usually 24#? ill know for sure when i change spark plugs next week and look at them closer
trinity_gt
3,125
81
99
Canada
Sep 3, 2011
  • Sep 3, 2011
An 02 GT pump is more than capable of working with 24# injectors.
How are you tuning for them? What tool are you using?
The plugs won't tell you much. They'll most likely be white-ish or tan because the PCM operates in closed loop most of the time. The amount of fuel delivered through the 24s during these conditions will be the same as that delivered through 19s. If you've got problems starting when cold it's likely the "tune" is still incorrect as Maxpowers suggests.
M
mustangjoe02
84
  • Sep 3, 2011
using my sf3 sct. but that helps alot. thanks guys
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 4, 2011
  • Sep 4, 2011
Hard start could be fuel pressure leak down. Try cycling the key on/pause/off several times without cranking. Does this improve starting? If so, suspect fuel pressure is leaking down between starts.
M
mustangjoe02
84
  • Sep 4, 2011
how would you know for sure if thats what it was? how to fix also?
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 4, 2011
#10
  • Sep 4, 2011
  • #10
So what are the results of the key cycling test?
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Fuel Fuel injector cleaner?
  • Creomod
  • May 29, 2026
Fox 5.0 Mustang Tech May 30, 2026
evintho
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
