  • SN95 4.6L Mustang Tech
injector install ?
  • Thread starter Thread starter Kickn4Macon
  • Start date Start date Oct 17, 2006
Kickn4Macon
Yorktown/Richmond
Oct 17, 2006
  • Oct 17, 2006
I need to put new fuel injectors in my '01 and was wondering if anybody has installed injectors on their own? It doesn't look hard, but that is my question. Is it a hard install and how long did it take??
Any help would be awesome, I'm looking foward to driving this thing again.
Saleen4971
664
Setauket, LI
Oct 17, 2006
  • Oct 17, 2006
really simple. relieve the fuel pressure (turn off the inertia switch and let teh car run till it dies) then take the 4 bolts out of the fuel rails, pull the rails up, remove old injectors, lube new injecto o-rings (white lithium grease or motor oil) put the injectors in the rails, then push em down, bolts em up and plug in the connectors!
sgarlic
3,085
Oct 17, 2006
  • Oct 17, 2006
I would recommend replacing the o-rings on the injectors.. other than that, the above poster sounded good.
Saleen4971
664
Setauket, LI
Oct 17, 2006
  • Oct 17, 2006
ahhh i knew i forgot something!!! they are pretty cheap too
1slo'96
17
  • Oct 17, 2006
it was a jiffy (bout 30 to 45min) not hard at all
jstreet0204
939
Winston Salem, NC
Oct 18, 2006
  • Oct 18, 2006
Not sure why you are changing them, but keep in mind, that if you are not swaping out the same size injectors, the eec has to be retuned. The physical install is easy.
Kickn4Macon
Yorktown/Richmond
Oct 18, 2006
  • Oct 18, 2006
Yeah I got a real bad slug of water in a tank right after they started putting ethanol in the gas and lost the 8th cylinder.... I changed the filter which was nasty, but it still isn't hitting on all 8. I was wanting to get it tuned anyways. I'm probably getting a diablo tuner.
Thanks for the help everybody
M
MatthewP
355
Calgary, Alberta
Oct 18, 2006
  • Oct 18, 2006
Use some motor oil on the o-rings to lubricate them when you do the install.
-Matthew
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
