  • SVT Tech Forum
Injector noise?
  • Thread starter Thread starter 2BADSTANGS
  • Start date Start date Jun 19, 2008
2BADSTANGS
385
Colorado
Jun 19, 2008
  • Jun 19, 2008
I have a supercharged 99' Cobra and i get a clicking noise through my sterio. It has the fuel injectors supplied with the procharger kit. The volume/ frequency changes with rpm+ throttle position. It is definatley not alternator whine. I'm thinking mabe coil packs, but leaning towards injectors. The coil packs are stock. I have compleely gone through the wiring testing for bad connections and bad grounds, everything is as it should be. I had this problem with the factory mach system and now with my Eclipse avn-7000. Anyone experianced problems like this with larger than stock injectors? Any advice would be great!
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Jun 19, 2008
  • Jun 19, 2008
You don't think it may be caused by non-resister plugs possibly? Do you have an aftermarket hood by chance?
U.M.
2BADSTANGS
385
Colorado
Jun 19, 2008
  • Jun 19, 2008
Stock hood
It has the factory hood. Had'nt considered the plug issue... I'll look into it. In the mean time, any other advice appreciated. Thanks Unc!
2BADSTANGS
385
Colorado
Jun 23, 2008
  • Jun 23, 2008
It's FIXED!!!!!
Ok, heres what it was. I checked the plugs that were in it and they were NGK race plugs. (They were resistor plugs) I started wondering if they were'nt taxing my stock coil packs. So after talking to a mechanic buddy of mine I decided to try a stock style plug instead of the race ones. Low and behold, problem SOLVED!!! No loss of power, (Maybe even an increase, though dyno results arent in yet.) no problems whatsoever!!! Apparently the race plugs were too much of a load on my stock coils. Thanks again for the lead unc!
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Jun 24, 2008
  • Jun 24, 2008
No problem man, glad to hear it's solved.
U.M.
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
6K
Other Auto Tech Jul 28, 2024
manicmechanic007
  • SVT Tech Forum
