Injector problem...
  • Thread starter Thread starter 88hatchblack
  • Start date Start date Jun 3, 2005
88hatchblack
163
Willard, Ohio
Jun 3, 2005
  • Jun 3, 2005
with the key on and the engine off, there is 12v coming from BOTH injector wires. is this normal??
BLOWN 5.0 FOX
213
NORTH SHORE MA
Jun 3, 2005
  • Jun 3, 2005
are you using a DVOM or a test lamp and assuming its 12v?
HISSIN50
34
129
Jun 3, 2005
  • Jun 3, 2005
the injectors should have a constant 12 volts with the key on. the puter sends a ground pulse to open and close the injectors. with the car not running, there should be no ground.
A noid light makes testing like this easier.
good luck.
88hatchblack
163
Willard, Ohio
Jun 5, 2005
  • Jun 5, 2005
from BOTH injector wires though?
K
KnowPlay
Banned
Jun 4, 2005
Swamp in Louisiana
Jun 5, 2005
  • Jun 5, 2005
Yes. The coil in the injector allows the current from one side to pass to the other. Thus, you will have voltage on both wires until the ECM pulses with ground. HISSIN is correct.
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Did I fry something messing with my ignition?
  • 85gtCOBRA
  • Oct 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2025
85gtCOBRA
