Injector Problems
  • Thread starter Thread starter BlackLX5.0
  • Start date Start date Jan 16, 2006
BlackLX5.0
76
  • Jan 16, 2006
The gas is running to the injectors but the injectors arent opening to let the gas go through. What could be the problem? Could it be the wiring or what do you all think?
Thanks :SNSign:
HISSIN50
34
129
Jan 16, 2006
  • Jan 16, 2006
The injectors get a key-on constant 12 volts and a pulsed ground (the ground is how the computer controls the injector being open, as well as for how long the injector is open). It is easier for the puter to control ground than 12 volts.
If you have a noid light, toss it on an injector to be sure.
Otherwise, see if you have key-on 12 volts and go from there. Jrichker has had some excellent posts of late (helping that guy out whose name starts with Z as I recall).
Good luck.
Z
ZephyrMotorspor
88
Tampa, Fl
Jan 17, 2006
  • Jan 17, 2006
Still no dice but i get my check today and i'll see about getting an actual noid light...as opposed to taping jumper wires onto a test light and sticking them into the injector plug
HISSIN50
34
129
Jan 17, 2006
  • Jan 17, 2006
Zephyr, as Jrichker said a day or two ago, please stop randomly posting on other peoples' threads. I get sidetracked when posting (I often just read the latest reply), and it is just kinda rude, especially since you have a thread or two going about your issue as it is.
I had typed out a reply to this one, until I realized it was Black LX's thread.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
1970 Mach 1 voltage regulator
  • 70ivygreen
  • Oct 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 27, 2026
Mcmahst
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
