Injectors not pulsing
jd69
Gentlemen, I need to identify why my injectors are not opening
I have 12 volts at the red wire, have back probed both wires with
A noid light, which does not light during crank. I believe the signal
Comes from the EEC....
Is it just one side of the injector harness?
When I bought my Bronco years ago, it didn't run at all. Used a noid light on both sides of the injector harness and found that one side wasn't working. I had to get a new computer for it.
Thanks for replying. Both i imagine. At this point the car doesnt even try to start. I would imagine if half of the injectors were firing, the car would at least try to start. Ive ran a code scanner, only to come up with a neutral switch code, but ive ignored that since the car doesnt even turn over if in gear. Cant believe that i drove into the garage one day, and the next she doesnt start...
If you would have looked closely at the "Cranks OK, but No Start Checklist for Fuel Injected Mustangs", you would have noticed that the PIP fires the injectors and the ignition. That points to a failed PIP sensor...
PIP Sensor functionality, testing and replacement:
The PIP is a Hall Effect magnetic sensor that triggers the TFI and injectors. There is a shutter wheel alternately covers and uncovers a fixed magnet as it rotates. The change in the magnetic field triggers the sensor. A failing PIP sensor will often set code 14 in the computer. They are often heat sensitive, increasing the failure rate as the temperature increases.
Some simple checks to do before replacing the PIP sensor or distributor:
You will need a Multimeter or DVM with good batteries: test or replace them before you get started.. You may also need some extra 16-18 gauge wire to extend the length of the meter’s test leads.
Visual check first: look for chaffed or damaged wiring and loose connector pins in the TFI harness connector.
Check the IDM wiring – dark green/yellow wire from the TFI module to pin 4 on the computer. There is a 22K Ohm resistor in the wiring between the TFI and the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 22,000 ohms +/- 10%.
Check the PIP wiring - dark blue from the TFI module to pin 56 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the SPOUT wiring – yellow/lt green from the TFI module to pin 36 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the black/orange wire from the TFI module to pin 16 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the red/green wire; it should have a steady 12-13 volts with the ignition switch on and the engine not running.
Check the red/blue wire; it should have a steady 12-13 volts with the ignition switch in Start and the engine not running. Watch out for the fan blades when you do this test, since the engine will be cranking.
If you do not find any chaffed or broken wires, high resistance connections or loose pins in the wiring harness, replace the PIP sensor or the distributor.
The PIP sensor is mounted in the bottom of the distributor under the shutter wheel. In stock Ford distributors, you have to press the gear off the distributor shaft to get access to it to replace it.
To remove the gear, first you drive out the roll pin that secures the gear to the shaft. Then you get to press the gear off with a hydraulic press or puller. When you go to press the gear back on, it has to be perfectly lined up with the hole in the gear and shaft. I have been told that the hole for the pin is offset slightly from center and may require some extra examination to get it lined up correctly.
Most guys just end up replacing the distributor with a remanufactured unit for about $75 exchange
PIP problems & diagnostic info
Spark with the SPOUT out, but not with the SPOUT in suggests a PIP problem. The PIP signal level needs to be above 6.5 volts to trigger the computer, but only needs to be 5.75 volts to trigger the TFI module. Hence with a weak PIP signal, you could get spark but no injector pulse. You will need an oscilloscope or graphing DVM to measure the output voltage since it is not a straight DC voltage.
See http://www.wellsmfgcorp.com/pdf/counterp_v8_i2_2004.pdf and http://www.wellsmfgcorp.com/pdf/counterp_v8_i3_2004.pdf for verification of this little detail from Wells, a manufacturer of TFI modules and ignition system products.
One of the reasons I am so frustrated by this situation is because I
Have performed many of these checks. I have installed a new MSD
Distributor, which means brand new pip/hall sensor. A new coil, EEC relay
And fuel pump relay, and a new fuel pump. I have confirmed spark
At the coil and at the plugs, 12 volts at the injectors on the red wire
New cap and rotor came with the distributor and I pulled the EEC out and
Supposedly they changed some capacitors. I am frustrated, but have followed
These steps you kindly posted prior to me logging in to this site. I am
Suspecting the EEC went tango uniform, and am thinking of putting my
86 GT 's EEC to see if this 5.0 will fire off. I have ran the code scanner, looking for
any help, and like I stated to the other guy all I had was a neutral gear code. I do
appreciate your comments, and would like to discuss this further, maybe along
the lines of a failed computer
In case you didn't know, MSD means "May Suddenly Die". Their product reliability isn't very good at all. There have been several instances of other Stangnetters getting a dead unit right out of the box.
Read the note at the bottom of my previous post concerning link to Wells, and the problems with PIP sensors. You'll find it matches the problem you currently have.
