Hey guys , got a little problim I could use some help with , Just finished building my intake and fuel system and I cant seem to get this thing to run right . The problim is that when I start the car it wont seem to Idle properly and heasitates when i open the throttle it sumbles and has a tendancy to die . I have a feeling that this may be a result of my earls filter not filtering fine enough and pluging my injectors (dang ) not sure if this is the problim or not but it is all I have come up with so far , any suggestions comments or criticisms are welcome and I thank you all in advance .
P.S I searched the forums for info on a similar problim but im not sure if i did it right
Here is some info on my combo
80mm cc&l mass air
42lb injectors
225 lph fuel pump
earls screen type fuel filter
70mm throttlel body
dart 195cc pro 1 as cast heads
Victor Jr. intake
timing set at 10 degrees ( yes I Know how to set it)
vortech s-trim
347 stroker
aprox 8.9:1 compression ratio
80mm cc&l mass air
42lb injectors
225 lph fuel pump
70mm throttlel body
Victor Jr. intake
vortech s-trim
347 stroker
