injectors size
  • Thread starter Thread starter donfina
  • Start date Start date Dec 30, 2005
D
donfina
  • Dec 30, 2005
bought 93 already had 30lbs injectors (red) throttle body 65 e303 cam forged pistons edelbrock performer cold intake what maf should i have seems to be lean
D
donfina
  • Dec 30, 2005
fuel pump?
runs lean when i get on it fuel pump?
D
donfina
  • Dec 30, 2005
hello
RyanSG
286
Allentown, Pa
Dec 30, 2005
  • Dec 30, 2005
Can you conferm what AFR your running when it seems to be going lean?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Dec 30, 2005
  • Dec 30, 2005
30# injectors are not required for a N/A application.
Have you had your Mustang hooked up to a dyno to see where you are leaning out? Do you have a wideband O2 setup? Your car being lean is a sign of something wrong.....
19# injectors are good up to 300 Horsepower
18mustangs
533
Virginia Beach, VA
Dec 31, 2005
  • Dec 31, 2005
If it's running lean when you get on it my first reaction would be fuel pump, are you still running the stock one? BTW, for your current setup 30# injectors are a bit big, you'd probably do well with 24#.
Tim
QDRHRSE
1,590
Palmdale, CA
Dec 31, 2005
  • Dec 31, 2005
I'm with the other guys. With 30's you should be rich. It also depends on your fuel pressure. If you don't have an AFPR-get one. If you do, give yourself a little more fp. If that doesn't work try changing the fuel filter. At that point you may want to consider a pump. Also, how do you know that you are running lean?
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
