Insane Rear brake conversion... ???
SN65
540
Chicago, IL
Hi All,
Silly question, but.....
I need to put the drum break setup from a 1967 mustang onto a current 9" currie rear end with a disk break setup.
Will the 67 drum setup bolt right on, or will there be extensive modifications???
Bob
If it's got the 4-bolt typical flange, then the drumbacking plate should bolt on with the axle retainer. You should be OK as long as you dont have wierd axle lengths that would put the drum in/out too far.
Cannoball888 said:
Why would you prefer drums to discs?
My guess is either the disks are too large for the wheels he wants to use, or more than likely his currie rear is 5 bolt and he wants to convert to 4-bolt (again probably because of wheels).
Well, I don't think it has anything to do with 4 lugs, the likelyhood of Currie building a 4-lug disc brake setup has to be close to nil.
That being said, there's nothing wrong with drums in most applications. I know I'd much rather push a drum car in the staging lanes at the track than a disc car, and a disc/drum car with a disc/disc M/C really sucks.
I ment it might be the other way around. The currie is 5lug but he has 4lug wheels and/or 4lug upfront.
I'd say probably not, most Mustangs used small bearing rears and most of the aftermarket rears are either big bearing or torino style. I would think it'd be alot easier to just find some backing plates from a big Ford with the proper bolt pattern and center hole...
68Restoman
