Install seal on timing cover
  • Thread starter Thread starter sparx
  • Start date Start date Jan 5, 2010
sparx
369
  • Jan 5, 2010
Any simple way to install the seal on the timing cover, inside mounted?
Better to get new timing cover that seal installs from outside?
sparx
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jan 5, 2010
  • Jan 5, 2010
sparx
How often you planning to replace this seal? By removing the cover and replacing the seal, you solve the problem for $25. If you replace the cover to use the "easier" seal, this goes up another $100 or so. I dunno about you, but I replaced this seal over 20 years ago and it's still in there, doing the job. Not untouched, either, I've replaced the damper twice.
sparx
369
  • Jan 5, 2010
I have the original cover off the 289, but the pitting on the gasket surfaces concerns me. And I am not much for piling on gasket rtv.
So, I think I may be getting a new timing cover anyway.
sparx
2+2GT
3,333
10
79
Jan 5, 2010
  • Jan 5, 2010
I don't use silicone sealant. I think about the bits that squeeze inside the engine and end up inside the lifters, etc.…
I use this on almost everything:
http://www.permatex.com/products/Au...tex_Aviation_Form-A-Gasket_No_3_Sealant_a.htm
sparx
369
  • Jan 5, 2010
I have looked at that stuff and read it works well.
How to install that seal... ?
2+2GT
3,333
10
79
Jan 5, 2010
  • Jan 5, 2010
Press the old seal out and the new in with a seal tool or large socket. I like to put a thin coating of sealant in the bore before inserting the seal.
dcstang67
127
  • Jan 5, 2010
I really wouldnt worry about that happening. The oil has to pass through a screen and a filter before it even comes close to the inside of the lifters. The normal breakdown of bearings ending up in the bottom of the oil pan will do more damage than some soft silicone that may end up in your oil pan.
D
For Sale 08 Mustang TMI seat covers/foams
  • Don7Up
  • Oct 3, 2026
  • Interior Exterior Parts
Interior Exterior Parts Oct 3, 2026
Don7Up
D
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
D
Paint removal on machined gasket surfaces.
  • Ddyer2868
  • Feb 16, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 23, 2026
ctandc
C
TPs sensors different?
  • Creomod
  • Sep 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2026
DadLife0724
O
8.8 Pinion Nut Leak
  • OX1
  • Jan 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
OX1
O
