  • SN95 4.6L Mustang Tech
Installation time?
  • Thread starter Thread starter PULMEOVR
  • Start date Start date Aug 3, 2005
1 of 2 Next Last
PULMEOVR
I need a bigger E-Penis.
Sep 29, 2003
560
Ottawa, Ontario Canada
Aug 3, 2005
  • Aug 3, 2005
Guys ... quick...
What is the installation time for springs and CC plates?
A shop is telling me that it will take 1.5 hours per corner. Is this right?
That means it will cost approx. $283 after taxes. (converted to American) for a complete job. Seems expensive just to install these minor parts?
No guesses please, just people who know. Thanks.
Matt
downsouthman1
643
Texas
Aug 3, 2005
  • Aug 3, 2005
PULMEOVR said:
Guys ... quick...
Matt
You could try doing it yourself. I've installed Springs & CC Plates on a 2000 GT a couple years back w/ a buddy & just yesterday I installed Springs on my Stang, mostly by myself. I think 1.5 hours per corner is very realistic.
PULMEOVR
Sep 29, 2003
560
Aug 3, 2005
  • Aug 3, 2005
How hard is it? I didn't want to screw with the suspension because I don't trust myself to, but is it that hard? I have a Haynes manual, but I am no mechanic.
So 1.5 hours is realistic, for a professional mechanic?
Thanks.
downsouthman1
643
Texas
Aug 3, 2005
  • Aug 3, 2005
Thanks.
I'm no mechanic. It took me 9 hours to install H&R Springs on my Stang yesterday. If you've never done it before, I would not recommend doing it yourself. It would be nice if you had a Mustang buddy who could help you. The only reason I did the install virtually myself yesterday was cuz I'd done to previous Spring installs. Or I could give you a thorough walkthrough if you'd like. It takes a lot of strength, so make sure you stay hydrated if you decide to do them yourself.
tomustang
Psychotic Member
3,434
McLean Hospital
Aug 3, 2005
  • Aug 3, 2005
Holy crap 9 hours?????????
I took 2 1/2 hours to do c/c's and springs.
downsouthman1
643
Texas
Aug 3, 2005
  • Aug 3, 2005
Braggart. LOL. I was working at a nice, easy pace, & taking plenty of water/Gatorade breaks & being interrupted by phone calls. Oh, & sorry, I forgot to mention that I also installed my C&L MAF System during that time span. Also, in order for me to get to the bolt on the top of my rear struts, I had to unbolt my stereo boxes and amplifier from my trunk. But before I did that, I tried using spring compressors cuz I didn't wanna hassle w/ unbolting my speakes and amp from the trunk. In other words, I wasted a lot of time when I wound up having to do it that way anyway.
CManT1914
3,172
Killeen, Texas
Aug 3, 2005
  • Aug 3, 2005
downsouthman1 said:
I'm no mechanic.
Ain't that the truth. j/k man
Springs are real easy actually. I'd recommend doing them yourself. All you gotta do is take off the wheels and brakes. For the rear, all you gotta do is disconnect the lower control arms lower mounting bolts, and the shocks, this will allow the lower control arms to drop down so the spring can come out. I put the car up on jackstands and used the hydraulic jack to hold the control arms in place until I was ready to pull the springs. Be careful to not drop the control arms to fast or the spring can pop out and cause some serious damage. Spring compressors are totally unneccesary, I haven't ever used them, and I've taken the rear springs in/out more than once. I don't remember how long the springs took me, but I tore apart my whole rear suspension to do my upper and lower control arms and put it back together in 4 hours. This was wheels, brakes, lower control arms, upper control arms, shocks, quad shocks, and sway bar. So for a beginner you can probably do all the springs and c/c plates in an afternoon. Good luck, let us know if you need some more tips.
DCjuggalo
169
Charlotte, NC
Aug 3, 2005
  • Aug 3, 2005
http://www.stangnet.com/tech/spring.html
thats the guide i went by when i installed mine (By myself)
http://www.mustangworld.com/ourpics/fcar/spring1.htm
and here's another incase that one gets u confused
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Aug 3, 2005
  • Aug 3, 2005
Thats their rate at 1.5 per corner it only took me 2hrs to do the whole car the rears are easy the fronts require a little more attention but easy none the less and CC are so easy because your already there.
Ryan's 02 GT
100
Fayetteville, NC
Aug 3, 2005
#10
  • Aug 3, 2005
  • #10
The hardest part about changing spring is playing with the spring compressor and realizing you don't need it. The compressor is usless. I did mine in the driveway in about 2-3 hours by myself. On the front taking out the strut makes it easier and with C/C plates they need to be unbolted anyways. On the rear I did not undo the LCA/s just the shocks. 1.5 hours per for a mech??? Not a good mech.
Ernad
celibate sans pants
Apr 2, 2004
Grand Rapids, MI
Aug 3, 2005
#11
  • Aug 3, 2005
  • #11
1.5 hours/corner seems reasonable in the front, but not in the rear.
jstreet0204
939
Winston Salem, NC
Aug 3, 2005
#12
  • Aug 3, 2005
  • #12
I am in the process of installing some steeda comp springs now. I did the rears this afternoon, and it only took me 1.5 hours taking my time. I'm doing the fronts in the morning, I'll let you know how long it takes.
forpit2000gt
2,490
Columbia, SC
Aug 3, 2005
#13
  • Aug 3, 2005
  • #13
A decent mechanic should be able to do this in about 1.5 hrs per side. Some shops use a program like the dealers use that gives the time per corner. That is not unreasonable for a shop that stands behind the work. I can't imagine someone in a driveway with hand tools doing this (all for corners ) in two hours on jack stands with one floor jack.
Ryan's 02 GT
100
Fayetteville, NC
Aug 3, 2005
#14
  • Aug 3, 2005
  • #14
Maybe I'm not understanding what the mech is doing in 1.5 hours. The rear is nothing more then putting the body on stands then with the jack on the pumpkin undo the shocks and the brakeline retainer. The front is more time comsuming but if you unbolt the struts from the top and I believe there is a brakeline there too. A mech with a left and the experience should definately not take 1.5 per. That is how these guys make a killing.
tdaily2
75
Greenville,SC
Aug 3, 2005
#15
  • Aug 3, 2005
  • #15
it can be done all 4 in 1.5 h but you have to be getting after it i have done this not once but twice and that is not but with hand tools
forpit2000gt
2,490
Columbia, SC
Aug 4, 2005
#16
  • Aug 4, 2005
  • #16
1.5 hrs is not making a killing.
you can do this yourself though. The rears you will unbolt shocks and upper control arms then drop rear as you stated. Getting the uca lined back up can be a PITA. Anytime I have to give a quote for my work , I always have enough time to cover my a$$. If I just do time and materials it almost always comes out cheaper.
jstreet0204
939
Winston Salem, NC
Aug 4, 2005
#17
  • Aug 4, 2005
  • #17
No need to unbolt the uca's You can unbolt the lca's or do like I did and just unbolt the shocks.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 4, 2005
#18
  • Aug 4, 2005
  • #18
If you worried about the cost do not forget to budget money for an alignment after that work is done...
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Aug 4, 2005
#19
  • Aug 4, 2005
  • #19
After i did my steeda CC theres 2 slots you can put the small one is for strett use the bigger one is for road race. I put it on the street slot at full neagtive camber for that slot which is -1.2 degrees and and full positive caster at 4.5 degrees when i took it for alignment the guy said that the alignment was good but since you are lowering the car yeah you should take it for an alignment.
PULMEOVR
Sep 29, 2003
560
Aug 4, 2005
#20
  • Aug 4, 2005
  • #20
Well, I don't think I'll do the springs myself, but maybe the CC plates.
Anyways, I guess 1.5 hours per rim is acceptable considering they also quoted the installation time of the CC plates in this.
Thanks guys,
Matt
1 of 2 Next Last
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
M
  • mnky99
  • Sep 5, 2025
mnky99
M
