  • 1994 - 1995 Specific Tech
Installed ASP underdrive pullies today
  • Thread starter Thread starter red95gtconvert
  • Start date Start date Feb 6, 2007
R
red95gtconvert
382
Ponca city, OK
Feb 6, 2007
  • Feb 6, 2007
UPS delivered my ASP aluminum underdrive pullies today and since in was nice out (65*) I decided to install them today. The install didn't take to long, probably because I didn't install the alternator pulley because I didn't want charging issues. After putting them on I took the car out a to nice backroad that could almost be used as a sanctioned road race course to see if they made a difference, all I can say is wow they woke my car up alot. The car revs up stronger and smoother and has a more powerful feel to it. No regrets on this mod
M
MustangGT95
407
  • Feb 6, 2007
Did you have to switch belts since you didn't use them all?
R
red95gtconvert
382
Ponca city, OK
Feb 6, 2007
  • Feb 6, 2007
Nope, I was able to reuse the stock size belt.
D
Danman765432
471
Nutley, NJ
Feb 6, 2007
  • Feb 6, 2007
You will still have charging problems even with the stock alternator pulley
R
red95gtconvert
382
Ponca city, OK
Feb 6, 2007
  • Feb 6, 2007
Hmmm, I turned on the lights and everthing else on the car and at idle the volt guage reads right where it did before the pullies were installed
D
Danman765432
471
Nutley, NJ
Feb 6, 2007
  • Feb 6, 2007
when the car warms up you will notice it to slowly go down...also watch out in the summer they could cause overheating problems too, that is why I am putting my stock ones back on....but they do really wake up the car.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Feb 6, 2007
  • Feb 6, 2007
When you have the A/C On too it will drain it a little faster. Just make sure to watch out for it. If your radio cuts off, give it some gas right away so it dosent die. I had to do that alot with mine.
Black95GTS
1,644
Marlborough, MA
Feb 6, 2007
  • Feb 6, 2007
I don't have any problems at all with all three of my ASP pulleys in place?? I don't have any kind of fancy sound system though. My battery is about two years old.
I LOVED this mod.
Adam
R
red95gtconvert
382
Ponca city, OK
Feb 6, 2007
  • Feb 6, 2007
I ordered an ASP overdrive alternator pulley tonight just for the piece of mind, I don't like dimming lights or my car cutting out
trav_19
810
Jackson, MI
Feb 6, 2007
#10
  • Feb 6, 2007
  • #10
i know i soooo regret doing underdrives on my 93 it is bad in that car..and as mentioned as you drive it goes lower ...and there is no charging at idle....totally sucks...
however the alternator in a 93 is much lower amp rating then what was installed in a 94 i believe the 93 had a 65a..? and 94 was a 100a...? maybe im wrong...i would like to do underdrives on the 94 but i see a lot of people having issues so it scares me and i feel its crapy to buy a pulley kit and not use all the pullies so i might stick with stock pullies until i get some solid evidence of the charging issues
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 6, 2007
#11
  • Feb 6, 2007
  • #11
You can make a significant difference on the amount of juice your
alt cranks out with just a couple of hundred rpm.
On a stocker or bolt on Stang ................
Peeps have no need for a higher idle
hence
You see them cry about ud pullies
H/C/I combos usually need an idle rpm of 800 to 900 rpm which
can give that advantage of extra juice from the alt
I got em on my 95 with no problems
Free rwtq ALL across the ENTIRE power band
The kinda deal .......... I just ain't gonna pass up
Grady
'94ChickStang
301
northern ca
Feb 7, 2007
#12
  • Feb 7, 2007
  • #12
Install the alternator pulley, you won't have any issues
Black95GTS
1,644
Marlborough, MA
Feb 7, 2007
#13
  • Feb 7, 2007
  • #13
hence
Grady
That's exactly why I don't have any problems. I have mine idleing at 750. It just seemed like more of a happy place and helped with some driveability. That must be the difference maker right there.
I didn't even think of that being why I don't have any problems.
Adam
D
Danman765432
471
Nutley, NJ
Feb 7, 2007
#14
  • Feb 7, 2007
  • #14
Adam
Do you get any overheating problems in the summer?
vp6799
124
Massachusetts
Feb 7, 2007
#15
  • Feb 7, 2007
  • #15
I installed MAC underdrive pullies and I have no problem. It idles at about 800 rpm's. No charging or overheating problems. Best cheap mod that I did.
Black95GTS
1,644
Marlborough, MA
Feb 7, 2007
#16
  • Feb 7, 2007
  • #16
No, I don't.
With that being said, I have used the TwEECer to kick on my fans slightly before the stock setting and I run a 180 degree thermostat.
Adam
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 7, 2007
#17
  • Feb 7, 2007
  • #17
That is the thing to keep in mind about our hobby.
We all got a Stang
but
Our expectations or goals for it
determines
Our application of how we use it
thus
It is not ALWAYS a black or white answer we can give others
when they ask for help, advise, or info.
I have often thought .......
Ya'll get tired of me seeming to focus
a lot of my replies around that phrase ........... it depends upon
anyway .......
You gotta admit it
If you pay attention
You can learn good stuff on these boards
I know I learn from you guys every day
Wish I had an internet when I got started in this hobby
Grady
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Feb 7, 2007
#18
  • Feb 7, 2007
  • #18
i never had any charging or cooling issues at all when i had the underdrives.
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
