Installed Eibach Pro-Kit springs, rear didn't drop at all.
Trick95
2,298
Detroit, MI
Hi everyone. I installed the complete Eibach Pro-Kit Springs and Dampers over the weekend. The front dropped a little over an inch but the rear is still at stock height. I did install polyurethane isolators at the same time too. Anyone ever experience this? I followed their instructions on spring placement inside the perch and verified part numbers etc.
Agreed with everyone, it does take a bit of driving before a set of springs will settle. It's also important to make sure you install the rear springs properly. Your ride height will change depending on which way the bottom of the spring is pointing. Both should be pointing to the driver's side. If they're pointing towards the rear or the passenger side, the rear will ride higher. If each spring is pointing in a different direction, the rear of the car won't be level.
