Installed MAC Pro Chamber & Now I have problems
cjhenry01
43
I just finished installing the MAC pro chamber. & now this!!!
At various times, I am experiencing hesitation while increasing throttle & some popping/backfiring during deceleration. The car just seems to have no power while this occurs. It will suddenly disappear for a awhile & then it comes back. I pulled codes & now I have a code 92.
What should I do?
Do you think I need to replace the right O2 sensor? Do you think it was damaged during the install?
I love the sound of the pro chamber but I would like for the car to run normal.
Please help!!!
By the way, it ran fine before the install.
Yes, I actually reset the computer two seperate occasions. I'm going to go buy some new O2 sensors tomorrow. I don't really want to spend the money but I can't seem to figure what else this sympton is from.
I bent my 02 sensor a little bit when i put mine back cuz there wasn't much room on the one side and wrench bent it in a little, luckily mine runs fine except for a what i believe is a vacum leak causing a surging idle if i set the rpms too low. Good luck with the new 02 sensors.
