  • SN95 4.6L Mustang Tech
Installed Throttle Body/Plenum!!!!
  • Thread starter Thread starter kyles03sonicgt
  • Start date Start date Feb 23, 2006
K
kyles03sonicgt
111
Berkley, Michigan
Feb 23, 2006
  • Feb 23, 2006
Well yesterday, I installed my accufab 75mm throttle body and plenum along with my jlt rai intake. The throttle body plenum was going fine, I was installing the new one, and as I was tightening a bolt on the accufab, a bolt snapped right off !!! This ****** was all the way in. I was freaking out, I didn't know what do to. So I took it off, tried getting it out with vice grips, no dice. So we decided to seal the hole with some gasket sealer. And boy did it work, with the bottom bolt on, it created a nice seal. I do plan on getting the screw out and get a new hole tapped, but it works like a champ for now. The intake was smooth sailing. As far as gains go, I wasn't expecting much. I noticed much better throttle response and that was about it. Once I get my full exhaust, I hope to notice more. Kyle.
BlackenedSVT
1,841
New Jersey
Feb 23, 2006
  • Feb 23, 2006
nice i'll be installing my extra stock ported plenum and FRPP 70mm t/b this weekend myself. I got them for free so i figured what the hell, gotta give me some gain
K
kyles03sonicgt
111
Berkley, Michigan
Feb 23, 2006
  • Feb 23, 2006
It's not a bad install either, just dont break the damn ford bolts. I guess they're not built ford tough. Just stay organized. You'll notice much better throttle response. And do you think the seal is good enough?? I cant pull the thing off, and I dont hear any leaks, what do you guys think??
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 23, 2006
  • Feb 23, 2006
one of the bolts snapped. that sucks.
you probally will develop a vacuum leak there. i would try and get that bolt out.
K
kyles03sonicgt
111
Berkley, Michigan
Feb 23, 2006
  • Feb 23, 2006
What are the tell/tale signs of a vacuum leak?? And it seems like I sealed it really well, and the air has no place to leave the plenum. There aren't any holes at this part of the plenum. With the gasket maker, will I still get a vacuum leak?? And how much would it cost to get that bolt out and re-drilled.?
Mike97gt
it doe snot
10,633
Feb 23, 2006
  • Feb 23, 2006
ok first you need to drive it around and see if it runs ok or if the CEL comes on. if it runs and idles fine and the cel is off then don't worry about it.
if it does come on do this. get a can of carb cleaner or intake cleaner spray. and spray at the base of the plenum in the corner near the broken bolt. when you hit the spot the idle will change.
drilling it out i not to hard. first thing i recomend you do is remove the plenum. then try a easy out. i like the kind that are LH ( left hand) drill bits. sometimes just the drilling will remove it. well you drill a hole down the center then use the special bit to try and twist the broken bolt out.
K
kyles03sonicgt
111
Berkley, Michigan
Feb 23, 2006
  • Feb 23, 2006
Car runs perfectly, never any idle problems or anything. Do you think I am alright??
J
joekd
51
  • Feb 23, 2006
When I installed my C&L plenum and BBK TB the only prob I had was getting the EGR unbolted, a lot of PB blaster and heating it up with a propane torch did the trick though and 15 minutes later it was off
Where's the pics of your new setup?!?!?
Mike97gt
it doe snot
10,633
Feb 23, 2006
  • Feb 23, 2006
yeah you are fine then.i would just leave it alone.
M
Mindstatic Pro
107
INDY
Feb 23, 2006
#10
  • Feb 23, 2006
  • #10
Was this a bolt holding the plenum to the intake? If the bolt is close to the top of the hole, you can lay a washer around the hole and tac it to the top of the screw, then just unscrew it.
loosescrew79
313
#11
  • Feb 24, 2006
  • #11
the carb cleaner is a great way to check it!!!!
i wouldn't mess with it unless you develope a leak. just check it every once in awhile.
how much did you spend for your set up? i have been thinking of getting a plenum and t/b
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Feb 24, 2006
#12
  • Feb 24, 2006
  • #12
when I installed my tb and plenum combo my freaking tps broke the next day while i was on the dyno lol
anyways, good stuff.. except for that bolt breaking
K
kyles03sonicgt
111
Berkley, Michigan
Feb 24, 2006
#13
  • Feb 24, 2006
  • #13
Ya, I'm defanitly gonna get that carb cleaner just to make sure. But i;m pretty sure i'm leak free. I really enjoy the better throttle response. Wasn't really worth the 430, but I mean once I get my bbk longtubes I'll see hella gains. I would recommend it to anyone.
ironmedic
1,361
Puyallup, WA
Feb 25, 2006
#14
  • Feb 25, 2006
  • #14
sounds like u over-torqued the bolt head. those bolts dont require alot of torque to lock em down. that is why they break--from overtorquing
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
D
Throttle Body Spacer
  • dropteeth
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
nicholase
G
Sputtering/misfiring below 2500rpm
  • Godless
  • Sep 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2025
gkomo
L
2004 Mustang GT issues after bolt-ons added
  • Leo090
  • Nov 1, 2024
SN95 4.6L Mustang Tech Jan 24, 2025
Leo090
L
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
