  • 1994 - 1995 Specific Tech
Installing a 9 inch in the 95
  • Thread starter Thread starter jdl95stang
  • Start date Start date May 29, 2010
J
jdl95stang
86
South Carolina
May 29, 2010
  • May 29, 2010
I want to put a 9 inch rear end in my 95. Just not really sure how to get the brackets all set up in the right places to be welded. I already have the 9 inch and dont want to have to redo the rear end again when i put a bigger engine in it, so i dont want to use an 8.8 even though it would be much easier to just bolt one in. Anybody know how to get it set up and welded in the right spots?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
May 30, 2010
  • May 30, 2010
It'll cost you twice as much to put the 9" in the car vs just getting the 8.8 done right. You'll have to give up your ABS if you have it, and probably you're parking brake too. In the end you're going to have an old clunky 9" rear that you spend more money on then just fixing your 8.8" rear end up right. The 8.8" is a much better axle, and parts have gotten very reasonable for it now.
Kurt
five0joe
  • May 30, 2010
Kurt
True story. If this is a track only car, maybe, but still more work and cost then making a 8.8 even stronger than the 9 inch. Sell the 9inch to someone who can reasonably use it and use the money to buy a 8.8 if you don't already have one.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
May 30, 2010
  • May 30, 2010
You can build an 8.8" to handle 2500hp. There is just no reason to go to a 9".
Kurt
MysteryMachine
1,835
Parkesburg, PA
May 30, 2010
  • May 30, 2010
A Fab9 would be hot though
J
jdl95stang
86
South Carolina
Jun 1, 2010
  • Jun 1, 2010
The 9 inch has already been built with a full spool and 3.73 gears. The parking brake is very simple to get all set up and I have no ABS. All I have to do is weld on the mounting brackets and bolt it in. I originally built the axle for my camero but I sold it when the trans went. So if I can get the mounts set in the right places, it wont cost me anything at all. Maybe just take the 7.5 axle out and measure where the mounts are welded?
M
Mustang Boy
23
Tampa Florida
Jun 2, 2010
  • Jun 2, 2010
are you sure that the rear end is the right width because it was built for your camaro and i doubt they have the same width rear ends as 94-95 mustangs
if it is a different width id recommend selling the rear end on a camaro forum(like ls1tech) and using the money to find an 8.8 to build which will be lighter than a 9in also
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jun 3, 2010
  • Jun 3, 2010
Doubtful it will be the right width. Those 9"s have a lot of heavy internals, and suck a lot of hp. It's going to slow you down quite a bit with a basic 5.0 engine. I still think it's going to be cheaper to do the 8.8. If the stock locker works fine, all you need is a set of forged shafts, which is under $300. That and a girdle ($150 range) and the rear end will hold 500 to the wheels with no problems.
Kurt
J
jdl95stang
86
South Carolina
Jun 4, 2010
  • Jun 4, 2010
Could be right. They are pretty heavy. I narrowed the 9 inch to about 6 inches narrower than the stock mustang rear end. So when I get my 460 all stroked out and built, will the 8.8 be up to the challenge?
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jun 4, 2010
#10
  • Jun 4, 2010
  • #10
Wait its 6 inches narrower than a mustang rear end yet u just want to bolt it in? Even if u get it bolted in....wheels wont fit. lol
J
jdl95stang
86
South Carolina
Jun 5, 2010
#11
  • Jun 5, 2010
  • #11
just bolt it in? Nope. Ive decided to build the car to take to the strip on a trailer and cruise around town once in a while. It will NOT be just a bolt in install for sure.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jun 5, 2010
#12
  • Jun 5, 2010
  • #12
Yeah, the 8.8 will be up to the challenge with 33 spline axles.
kurt
J
jdl95stang
86
South Carolina
Jun 6, 2010
#13
  • Jun 6, 2010
  • #13
What is the average amound you would expect to pay for an 8.8?
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jun 6, 2010
#14
  • Jun 6, 2010
  • #14
Depends on what you want to get out of it. For a basic Foxbody it goes as such for parts. Obviously labor is going to be on top of this, and it varies in price a lot.
1. Locker rebuild - $100
2. 28 spline shafts - $280
3. Girdle - $150
4. Gears - $240
5. Weld the tubes to the pumpkin
Strange just started making 31 spline axles (maybe 33 as well) that work with the stock disk brakes. Not sure how much those are. If you have disk brakes then you don't need to do a C-clip elinator kit. If you go with a drum brake setup, you're going to need to do a C-clip eliminator setup. Not sure how much those go for these, days, I haven't checked into it in awhile. Drum brakes are also going to require a different master cylinder.
Kurt
J
jdl95stang
86
South Carolina
Jun 8, 2010
#15
  • Jun 8, 2010
  • #15
Thank you. I can do all the work myself, so that wont be to bad at all. As for the used 8.8 itself? How much wold you expect to pay?
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 10:17 PM
AeroCoupe
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
