Installing a rear end easy or hard????
1FatPony
241
Do do you install a rear end?? Is it hard? Is it just bolt on?? I basically have a V8 mustang with no motor and a I6 rear end just so it could be rolled around. I want to put the rear end for the V8 back in. Can I do it?
I just installed a new Currie 9+ under my mach and it's really easy.
While The old rear was out, I used that opportunity to wire wheel the undercarriage, put a layer of rust encapsulator, and more undercoating on. That made it take a LOT longer than just the replacement.:D
How does this one look?? Should I use the original axle?
