Installing bushings??
  • Thread starter Thread starter Mavrick
  • Start date Start date Aug 19, 2004
Mavrick
2,264
Collingwood, ON
Aug 19, 2004
  • Aug 19, 2004
Whats the propor way to get these bushings in the housing? I'm referring to the upper rear control arm bushings, that go into the rear diff housing.. do i just hammer them in with a hammer, or what? I don't wnat to damage them...
Rick 91GT
Mustang Master
95
99
PA
Aug 19, 2004
  • Aug 19, 2004
Use a small drill bit and drill a series of holes through the rubber, it will eventually grab and come out in a few pieces.
You need the sleeves for the replacement bushings unless you bought new ones. Clean the sleeves out good, most new bushing come with some type of liquid/silicone to put on the new bushings before pressing them back in the housing. They are tight to get back in, you can make a press to do it or press them in by hand and use a deadblow hammer or a hammer and a block of wood.
Maximum Motorsports sells a nifty little tool to install and remove them as well.
Mavrick
2,264
Collingwood, ON
Aug 19, 2004
  • Aug 19, 2004
Cool. The ones i bought from DaSilva's are already packed in the shell so thats no biggie. I'll try to hammer them into the housing with the deadblow.. if not, a block of wood and "Thor" should do the trick
thanks
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Suspension CC Plates bushings and sleeves?
  • Scott_S
  • Apr 16, 2026
Fox 5.0 Mustang Tech Apr 16, 2026
Mustang5L5
